Adding subwoofer to surround sound system
I'd like to add a sub woofer to my aiwa sorround sound system-There's a plug in back that's labelled for it-What do I need to purchase & how much (as cheap as possible) will it cost me?
Thanks in advance
Username: Joe_s
Post Number: 41
Well, you already know you need a subwoofer, and then there's the cable from the back of your amp to the sub. That's all you need. Most amps and subs have RCA connections for coax cables. Like everything else, the prices vary tremendously, and price isn't always the same as quality. How much do you want to spend? Joe
