Cambridge AZUR 640C + NAD C352ct + Amphion Helium 2?
Any comments on the above-mentioned set-up? My budget is about £1500.
Thanks!
Username: Artk
Albany, Oregon USA
Post Number: 1503
Looks good to me why do you ask?
I was mostly concerned with the Cambridge as I was less than impressed with the AZUR 640 CD + Amp combination I listened to. Any alternative CD player s I could check out?
Username: Artk
Albany, Oregon USA
Post Number: 1508
The NAD C542 goes very well with their amps. With the Amphion speakers you could even go higher end than NAD. However the NAD gear should give you good low cost hifi sound. I know I know like mine very much.
Username: T_bomb25
Dayton, Ohio United States
Post Number: 698
Where are you located?The Amphion speakers the whole line is one of thest kept secrets on the market they are very good,If you already own a cd player I would go for a better amp.
