New member Username: Cheezel_xPost Number: 1 Registered: Aug-05 | in the remake of the italian job at the end you get to see 'the napsters' stereo system that he wanted to buy from the beginning, which has NAD T770 and a Burr-Brown DAC. however he dosnt state what the speakers are... heres a capture from the dvd, i tried to make it as good as i could h**p://flickr.com/photos/73958596@N00/33539716/ [the big middle thing is a speaker too i believe] |
Bronze Member Username: QuinnPost Number: 24 Registered: Aug-05 | The one in the middle is a Martin Logan. http://www.martinlogan.com/speaker_gallery.html I can't make out the others from that picture. |
New member Username: Cheezel_xPost Number: 2 Registered: Aug-05 | thanks quinn! |
Silver Member Username: Thx_3417Post Number: 797 Registered: May-05 | Woo Those Martin Logan loudspeakers, they cost an arm & a leg? |
Silver Member Username: KanoPost Number: 574 Registered: Oct-04 | Depends on which ones, the hyprid driver/electrostac retails for around $1000, and it's up from there to their pinnacle system the Statement E2 - http://www.martinlogan.com/statement_speaker.html which retails in the neighbourhood of $75,000, plus components that can properly drive them to their best $$$$$ |
Silver Member Username: CheapskatePost Number: 194 Registered: Mar-04 | if you want the same sort of sound as martin logan but at a much more reasonable price... look into Magnepan planar speakers. these flat panel speakers start at just $500 a pair for MMGs (i want em' soooo baaad! LOL) i was totally converted from a 20 year diehard fan of acoustic suspension minimonitors to a planar freak when i heard a $1200 pair of maggies that had the most "invisible" midrange i'd ever heard. lighning fast... and even the rolled off bass stomps my sluggish 12" sub for QUALITY. as a side note... if you want to see martin logans more often in video... watch "friends" one of their apartments has martin logans. how people struggling to get by in an expensive to live in city that can affors logans amazed me. it's probably the ONLY thing i know about the show oo. LOL magnepans are THE BEST value in high end. i liked those $1200 maggies with "entry level gear" more than the shop's $20,000 B&Ws driven with another $40,000 worth of macintosh gear. the B&Ws had more bass, treble and image specificity... but the maggies has gobs of speed and midrange coherency. they just sounded less like speakers. |
