How to connect discman to amplifier?
Prescot
Hey there!
I recently purchased a TEAC integrated stereo amplifier.
I plan to hook it up to my Sony Discman.
The question is: should I connect the Discman through it's "line out" or through the "headphone out"?
Does it have anything to do with this switch on the amp labelled "Source Direct"?
Please help.
Muchos Gracias.
Prescot
Username: Project6
Post Number: 407
it is best to use the the "line out".
Username: Gman
Mt. Pleasant, SC
Post Number: 353
Sony sells for $5.49 on their Sony Style site adapter cables to connect the Discman or Walkman to inputs on the back of your receiver.
You can probably get the same adapters from Radio Shack for much less, as normally the Discman has miniplugs that need to be adapted to RCA plugs to input into a receiver.
The Discman's line outs can be connected to any open inputs on the back of the receiver, with the exception of phono inputs, which have a different load.
