Username: Krazymofo24 Dallas,
Texas
Post Number: 2 Registered: Aug-05
Thursday, August 11, 2005 - 22:47 GMT I'm buying speakers one piece at a time. I bought the B-2's for my Fronts until I get the B-3's the matching surrounds are the Klipsch's S-2's will the B-2's work good as surrounds or will I need the S-2's?
Username: Devils_advocate Post Number: 170 Registered: Jul-05
Thursday, August 11, 2005 - 22:57 GMT The B-2's will probably be adequate for the purpose.
Username: Devils_advocate Post Number: 171 Registered: Jul-05
Thursday, August 11, 2005 - 23:00 GMT Also, have you considered getting 5 B-2's all around?
Texas
Post Number: 3 Registered: Aug-05
Thursday, August 11, 2005 - 23:31 GMT Would the B-2 sound good as a center? I would rather do that sure would save me money. B-3's, B-2's, and C-2= atleast $750. 5 B-2's = Around $500 I think i'll try that the B-2's sound so much better than the Bose 161's I bought first.
Username: Devils_advocate Post Number: 172 Registered: Jul-05
Thursday, August 11, 2005 - 23:41 GMT So long as you keep it vertical and the tweeter at or pointed to ear level, the B-2 will perform very well as a center speaker. The bonus of this configuration is that the system will integrate much better as the speakers will all voice/timbre match one another.
