Unregistered guest | I have a memphis 250 class d amp and 2 memphis pr104 10" speakers, I have the speakers conneted both together and bridged onto the amp because the box i have only has one terminal and it sounds alright but i think it can sound much better. should i get a box with two terminals instead of this one which has one and then bridge it . I believe it would sound much better if i did that but I`m not sure.Any advice on what i should do |
Silver Member Username: Joe_cAtlanta, GA Post Number: 924 Registered: Mar-05 | Yes you should start here: https://www.ecoustics.com/electronics/forum/car-audio/40.html |
