Bush PDVD0801 Portable DVD Player
Candide
Hi, I'm planning on buy the Bush PDVD0801 portable dvd player (£145)
I was looking at the model, and it doesnt appear to say anything about whether I would be able to hook it up to a proper TV in order to watch dvds. Does this mean I can only wath dvds, using the this product's 8inch screen?
It does say that it has an "optical out".
What exactly is this?
Thanks for your help.
Dazinblack
Yes you can hook up to the TV it has a cable for that purpose also you will be able to connect to you Hi fi as well
Optical out is used to connect the player to the TV
hillman
optical out is aa audio digital connection for a suitable amplifier, not for a tv
I was also planning to buy this DVD, can't tell from the picture/minimal spec whether it actually swivels and folders flat to watch?
Also do you know how to make it multi regional?
Is there a recommended car kit for it?
