New member Username: JgmanPost Number: 1 Registered: Mar-04 | Looking to upgrade my PSB Image 2B's to the PSB Stratus Mini's. I'm using a NAD 743 as my reciever. Does this receiver have enough power to drive the Stratus Mini's? Should I look at some other speakers? Thanks. |
Unregistered guest | Listen to the Green Mountain Audio Europa's For under $900.00/pair, i've heard nothing under $6k that competes. http://greenmountainaudio.com/ |
New member Username: Lockaudio801Post Number: 7 Registered: Apr-04 | Before you upgrade em` check if your using good speaker cables they make a heck of a lot difference if you try listening to your PSB's on lets say Cardas Golden Cross speaker cables? Or check to make sure if the direction of energy flow from your intrconnects and speaker wires from your NAD are in the right path.All things being equal you have a good sounding system. Your room acoustics could also be a problem seek to improve as they say tweak first then tweak again. |
