New member Username: WoosaPost Number: 1 Registered: Aug-05 | I'm new to the prosumer class audio, and I just got a Denon 3805. I would like to know which brand and set of speaker should be best (heard some rummors that Paradigm doesn't sound too good with Denon) for the Denon receiver within $1500 budget. I'm looking for something that would sound good both with movie and music listening. Thanks in advance for your comments. |
Silver Member Username: Joe_cOakwood, Ga Post Number: 883 Registered: Mar-05 | PSB image series. |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 1451 Registered: Feb-05 | Paradigm sounds fine with Denon. Bradford's in Eugene, Or. sell them together successfully. Paradigm's Monitor series is a good match. The PSB Image series as Joseph has pointed out would be a good match as well. Frankly there are a lot of good budget speakers that work well with your receiver. |
Silver Member Username: DmwileyPost Number: 961 Registered: Feb-05 | Your best bet is to listen to some speakers and choose for yourself. I respect Joe and Art but they can only give opinions based on their respective listening skills and biases. Useful information, but far from definitive. |
Silver Member Username: Joe_cOakwood, Ga Post Number: 885 Registered: Mar-05 | Since I have not disagreed with Dale in while, I will have to disagree. |
Silver Member Username: Frank_abelaBerkshire UK Post Number: 725 Registered: Sep-04 | M&K K-Series - pretty awesome and I think they're about that money in the US. If not, apologies in advance! Regards, Frank. |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 4931 Registered: May-04 | Bose. HAHAHAHAHAHAHAHAHAsnort |
New member Username: WoosaPost Number: 2 Registered: Aug-05 | Thanks for the constructive comments guys. I thought I've heard that Paradigm's monitor series doesn't have magnetic shield. Is that true? I will check out the brands from other suggestion. Thanks again!! |
Silver Member Username: Joe_cOakwood, Ga Post Number: 890 Registered: Mar-05 | Jan is a Kraco salesman. |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 4941 Registered: May-04 | I still have my pin which reads; Whip me, beat me, make me listen to mid fi! |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 1469 Registered: Mar-05 | Bose is low-fi not mid-fi, IMHO. |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 1470 Registered: Mar-05 | Woosa, browse through this site especially the reviews section: www.ascendacoustics.com |
Silver Member Username: Joe_cOakwood, Ga Post Number: 897 Registered: Mar-05 | Looks like a terrible speaker line Edster. lol |
CoolieBoy Unregistered guest | Hi All... I have one question, I am hooking up my polk Rti4's into my HK-AVR 635, and i am using a 5.1 setup. My question is... what input does the speaker go into, the R&L surround, or R&L surround back. The surround speakers will be behind the listener. Does it matter where it goes into?? |
Silver Member Username: T_bomb25Dayton, Ohio United States Post Number: 590 Registered: Jun-05 | No Eddie Bose is NoFi |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 1475 Registered: Mar-05 | heh heh to both of youse! |
Bronze Member Username: ZorroPost Number: 20 Registered: Jul-05 | Cerwin Vega D9- behemoth speakers ![]() Seriously, are you looking for bookshelves or Floorstanders?? I would add Monitor Audio to the list of suggestions. |
Gold Member Username: Paul_ohstbucksPost Number: 1892 Registered: Jan-05 | LOL I agree with Zorro. Unless you want a 'small' sounding HT system, you should avoid buying small halfpint speakers because thats exactly what you'll get by doing so. |
Silver Member Username: FalpPortugal Post Number: 144 Registered: Mar-04 | Quad L sound awesome with the 3805 AE Elite sound very good too Anyway avoid metallic tweeter speakers with the Denon |
