HK AVR 635 & Marantz SR-5500 - Lip Sync
Username: Raks
HK AVR 635 Owners: Can you please confirm the maximum Lip Sync Delay in milli secs that you can cover using the Lip Sync Delay feature on your receiver ?
Marantz SR-5500 Owners: Can you please confirm the maximum Lip Sync Delay in milli secs that you can cover using the Lip Sync Delay feature on your receiver ?
This will help me in deciding which reciever to go with ?
As always thaking you all for your input
Username: Ziggyzoggyoioi
Outside Philadelphia, PA
Post Number: 92
All of the HK x35 AVRs except for the 135 have a Lip Sync Delay.
Username: Raks
Post Number: 9
ZiggyZoggy....Thanks for letting me know. But can you Specify the highest value of delay ( like 160 milli secs or 200 milli secs or ?? ) you can set on HK AVR 635 ?
Username: Jimpaum
Raleigh, NC
Post Number: 10
According to the SR5500 user manual, "The initial setting is OFF (0 ms). The time lag can be adjusted in 10 ms steps up to 200 ms." They add a note that in Pure Direct mode, the lip sync feature turns off.
Username: Raks
Post Number: 12
Jim,
Thanks a lot for letting me know the details. I appreciate your help.
Raks
