Indoor Antennas .... worth it?
Username: Xmetalfanx
Englewood, FL United States
I have an Aiwa minisystem that came with a standard wire antenna. I am looking at some 10-20 dollar indoor antennas from companies such as RCA ... anyway, the problem is the wire antenna "plug" is very small.. just enough for the wire, and some of the antenna's I am seeing are all Coaxial cables (surely more for TV then FM)... my question is, Is there an adapter (tried radioshack.com but I couldn't find it) I can use to be able to try these antennas... I have OK receiption with the wire FM Antenna and the AM antenna both plugged into the FM Antenna Outlet, but i do havve the wire AT hanging in the middle of my room and if i forget its there .. .WATCH out.. Hehe... ...
thanks for all comments and suggestions .. :-)
Need to Register?
Forgot Password?
Enable HTML code in message
