Hi, guys, I need some advise on adding a RB-991 amp to my system, I have a Marantz Sr-19ex reciever and JM lab 816 front Jm lab 800 center speakers. Rears are Klispch Rs-35. A PSB 6i susonic sub. My question is adding the Rotel amp a good idea. I would like to have alittle more lower bass and tighter bass than the Marantz puts out. I listen to music 70% and movies 30% of the time . I would love to hear your feedback on this. Thanks JT
harana
I have the SR19EX with a Rotel rmb1075, using the 3 channels in front connected. major improvements in sound and dynamics. highly recommeded approach. sorry, not familiar with RB-991, but if it performs like any of rotels, then I would advise that you go with it.
The Marantz will perform well as a pre-pro. You have your choice of many fine 3 channel amps. Rotel, NAD, Outlaw, to name a few. You didn't state a budget, but to go up from there, look at Adcom, ATI, Aragon. Go out and listen.
Nice receiver BTW, I have an SR series amp in my closet, a SR880. Good luck.
