Suitable speakers for Cambridge Audio
Username: Garo
Ladies / Gents,
I'm a newbi in the world of Hi-Fi and have taken the plung to invest in a complete home hi fi set up.
I've read many a review on CD players and amps and have decieded that the Cambridge Audio AZUR series (probably the 340's) are right for me.
I'm pretty stumped however about which speakers would be best suited to the amp.
I wanted a pair of standmounts at a resonable price.
The Wharfedale Diamond 9.1s have caught my eye, would anyone recomend / discourage using these??
Any advice would be appreciated
Username: Stu_pitt
NYC, NY
Post Number: 378
I recommend using what you're heard. Listen to as many different speakers as you can with your equipment. If the store doesn't have your gear, bring it with you. If they won't let you bring it in, find one that will.
Username: T_bomb25
Dayton, Ohio United States
Post Number: 513
Wher are you in the world? what is limit that you are gonna spend?
Username: Garo
I'm in the UK, I can't get away with spending any more than £200 (thats about the same value as the amp itself and i think about $360)
Thanx
Username: T_bomb25
Post Number: 517
I would look to the Usher s520,and the Epos Els 3 and you already listed the 9.1 I would audition those three.
Username: Garo
LondonUK
Thanks for the help, will audition all three!!!
