i am not sure what i did wrong but i am getting this message: 'The iPod "Maria Cook's iPod" cannot be updated because all of the playlists selected for updating no longer exist.' i deleted it trying to create a new one. i am not clear on how to put playlists on my ipod and now i can't do it at all.
You have to make your playlist in itunes and it will sync with your mini.
Anna____
Im having the same problem with my iPod and PC World are useless. they told me to ring apple and there was nothing they could do, which is annoying. Apples only open from 11 - 5, and im out all of these times and it would also cost a bomb. i want a decent solution, if anyone has any suggestions i'd appreciate it, and if people have the same problem - try phoning 0208 218 1000 if you want proper help from apple -- dunno how much good it will do...
but please, HELP!
Mikey Aitch
Hi
Had the same problem myself and the following sorted it out:
Select Edit Select Preferences You will probably find that 'Automatically Update Selected Playlists Only' is selected Change to 'Automatically Update All Songs and Playlists' Select OK Hopefully this should solve things
Maree
Mikey, just surfed on in here after Googling this problem and wanted to say thanks so much! My iPod's sorted.
adey
Hey Cheers Mickey Aitch. Ur a lifesaver. i was crapppin me self wen it sed that dodgy message. Thanks again.
lisette
yay. i just googled it too, and this just saved my life. i was so worried. thanks!
kyih
that didn't work for me i changed it to "'Automatically Update All Songs and Playlists" and everytime i connect my iPod nano to my computer and i click on the iPod option it always switches back to "'Automatically Update Selected Playlists Only"
Downsey
Mikey!!! WOOO!!! Just updating ipod befor i went to bed and i got that error, put it in google and BAM found this, thx a bunch
ChrisVB
Me too... Googled and am now very grateful. Mikey is the Daddy!!!
Mickey D
Whoo! Mikey you're my hero! (plus you have the same name as me!) Cheeeeeeeers for sorting that out- otherwise I couldn't have listened to Radiohead on the tube!
-x- Rach -x-
Thanx soooo much!!! I searched for help with this problem in google too!
ICS
Same - another iPod fixed. Pity Apple couldn't make iTunes a little more intuitive!
Hector34
Thanks a lot!
Another satisfied googler!
Philip D
you rock so hard, mickey. thanks! i know i hit the other one durring setup....
ahmed_ipod problem
Woo i just googled it and found this! Your the man..!
pixelism
Mikey Aitch LEGEND!
My ipod is all fixed now!
pixelism
Mikey Aitch LEGEND!
Mikey Eff
Mikey Aitch Brilliant...problem solved in 5 minutes !
Caitlyn Todd
Cheers Mickey Aitch. You saved me a trip to the apple store at the very least. You rock.
Snowboarder420
Worked like a charm to fix deleting my playlist. Thought I'd have to reinstall.
Thanks to the Mikey & the Post Host!
Snowboarder420
Thanks to the Mikey & the Post Host! Gooogle rules!
Leah
fankoo mikey u star!!!
Leah
fankoo mikey ur wkd
Leah
fankoo mikey ur wkd
stevensmith
Googled it as well.. thanks for your help Mikey! Canada loves you!
Lyn Van Garling
Thanks Mikey Aitch, you've saved my day muachh..you rock!
Guilherme Filardi
Mikey Aitch: Thank you so much. My problems are solved! Brazil thanks U2!!! Cheers!
Mikey Aitch, YOU ARE THE MAN! I spent an entire afternoon on this problem I googled and there you were! BLESS YOU!
BEVERLEY
thanx mikey, it worked for me!! i was stressing out of my mind!
i think the problem arises when ur i-pod memory becomes filled up to da max so i-tunes decides to copy certain songs
Q. IF I DELETE CERTAIN PLAYLISTS WILL IT UPSET ANYTHING BECAUSE MY MEMORY IS BECOMING FULL????
ilovemike
Mikeyyy: did you ever know that you're my heroooo? and everything I'd like to beeeee... I can fly higher than an eaaagle when you are wind beneath my wings...
haha. THANK YOU. i almost cried last night 'cause i lost all of my songs. (I didn't care about my Midler stuff, though. ehem.) you rawk.
The iPod "Luisa's iPod cannot be updated because all of the playlists selected for updating no longer exist.<<<<<<<<<<<<<y>>>>>>>>>The iPod "Luisa's iPod" cannot be updated because there is not enough free space to hold all of the songs in the iTunes library.Would you like iTunes to choose a selection of songs to copy to this iPod?<<<<<<<<<<<<<<but then i see that my iPod doesn't have any music or pictures but it still says it doesnt have space so it selects like half the songs on my library but i dont want half i want all of them there so please some1 help me before i go crazy trying 2 fix it but end up messing it more
OMG!!!! JUST WANTED TO SAY THANK YOU SOOOO SOOOO SOOOO MUCH!!!! =) WOW, I WAS COMPLETELY FREAKING OUT, UNTIL I TOO GOOGLED THIS, WOW, THANKS MIKEY!! =)
