Speaker box filler
Username: Sandman670
Chicago, IL
Just a simple question-- would small 2.1 computer satellite speakers benefit from PolyFill inside? I recently took them apart and noticed their thin, resonant plastic construction.
I know this is done with subwoofer boxes to increase the effective volume (dimensional).
Should I just try to reinforce against vibration instead?
I know theyre crappy speakers but I was thinking if I can do something for $5 that makes them sound better why not.
Username: Jan_b_vigne
Dallas, TX
Post Number: 4776
For $5 you can take it back out if it doesn't help.
