Silver Member Username: DanmanQUEBEC CANADA Post Number: 436 Registered: Apr-04 | http://www.avsforum.com/avs-vb/showthread.php?t=563866 |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 1390 Registered: Feb-05 | Thanks for the link Danman. We NAD freaks must keep on representin'. |
Silver Member Username: Unbridled_idChicagoUsa Post Number: 118 Registered: Mar-04 | Update- I've heard that the retail price of the integrated amp, pre/pro, and 7 channel power amp all will be $2500. The disc player will be $1800 - $2000. |
Silver Member Username: Unbridled_idChicagoUsa Post Number: 119 Registered: Mar-04 | Even more on the new integrated: Integrated amplifier M-3 NAD High end reference class amplifier. the new M3 embodies all what one would expect from amplifier of the highest class; largely cooling fins and a high performance power supply offer pure sound performance, perfect processing with solid aluminum front plate. Into the chassis - With the M3 dual mono amplifiers are powered by two protected Holmgren toroidal transformers. Only finest parts are included. Bjorn Erik Edvardsen designed the M3 for the the best discrete circuit design. The volume is performed via several precise, discretely developed variable resistors. Also the features are not too sparse; 2 separately adjustable pairs of loudspeakers, Multiroom output with invidual source choice and separate remote control, treble and Bass equalization, an individual configurable Crossover between Pre Out 1 and Pre Out 2 (ex.s in combination with Subwoofer) 2 x 180W RMS 2 x 540W maximum performance 7 high level inputs, 1 XLR input (symmetrical) preoutput stage isolatable Holmgren single-aperture core transformer soft Clipping, power drive __________________________________________________ _______________ The fact that Bjorn Erik Edvardsen (whose intials on a model number designate NAD's 10/10 rule where you would have to spend 10 times the money to get a 10% performance increase, example- C320BEE) has a hand in this must mean that NAD kept this line in house instead of sub-contracting it out to another company as they did the Silver Series. |
Silver Member Username: DanmanQUEBEC CANADA Post Number: 440 Registered: Apr-04 | WOW! |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 1399 Registered: Feb-05 | Good info. |
Silver Member Username: T_bomb25Dayton, Ohio United States Post Number: 519 Registered: Jun-05 | Hmm.....that looks extremely interresting,its sure is gonna be one of the most stunning looking pieces on the market.When is it comming out? |
Silver Member Username: DanmanQUEBEC CANADA Post Number: 447 Registered: Apr-04 | I heard early Fall........but not sure! |
