Magnepan MGMC1 / MGCC2 Multichannel Speaker System
maxxy54
Any feedback on these speakers?
Username: Rick_b
New york Usa
Post Number: 46
As i have said in previous posts, in fooling around with this stuff for 34 years, Maggies are the best speakers I have heard or owned at any price.
I urge you to go and check them out for yourself. You won't be dissappointed. The MMG's @ $550 a pair are the best bargain in audio. Good luck.
maxxy54
Thanks Rick! I will check them out. I was actually think about getting their little brothers because my media room ia pretty small with a lot of windows. Do you have any feedback on them?
Username: Rick_b
New york Usa
Post Number: 53
I Have not personally heard the "wall hangers", but should sound like the MMG's. They share the same basic technology. In a small room they should sound great.
maxxy54
Rick -- Thanks! Would you have any feedback on these speakers being paired with a Cambridge Audio Azur 540R?
Username: Rick_b
New york Usa
Post Number: 157
Have not had a chance to hear the 540R.
Just keep in mind Maggies need good clean power. They are a 4 ohm speaker, so make sure your receiver can drive a 4 ohm load. My first choice in a receiver would probably be a NAD.
