Athena AS-B2 vs Infinity Beta 20
Max C
I'll be pairing these with the HK3380 stereo receiver...
Both are in the $150 range for a pair of bookshelves, though I can get the Infinity Beta 20 for $90 a pair through circuit city employee purchase.
I'll pay the $150 if the Athenas are that much better, so I'm just looking for opinions.
Thanks
Username: Devils_advocate
Post Number: 90
Your opinion is more important than ours. Have you listened to both speakers?
Username: Rsxman
Post Number: 30
I would test both of them first, but since I have athenas, id say go with that before Id get infinity speakers
Username: Occam
Post Number: 39
If you compare the B 20's to the Athenas post the results.
