Subwoofer directly to TV?
Username: Ccs
I bought a Sony KV-32HS510 TV which has RCA Video/Audio output too.
Now I see this Velodyne VX-10 10inch Subwoofer offer ($150 instead of $300) which says:
"RCA inputs for connection to the subwoofer/LFE output of a receiver or processor and spring-loaded, high-level inputs"
Now, my question: can I connect this sub directly to my TV, or I need receiver?
Thank you!
you should be able to just as long as the are low level outputs out of the tv and low level inputs to the subs
There isn't, Anonymous (no low level outputs).
It will not sound right, Csaba. You need to process the signal output from your TV through a receiver that perferbly has pre-out for a subwoofer.
