Bronze Member Username: Urlacher
Post Number: 61 Registered: Apr-04
Posted on Hi....does anyone have this receiver and if you do do you like it? Thanks |
Silver Member Username: Virus5877
West Lafayette,
Indiana
Post Number: 162 Registered: Apr-05
Posted on The better question David, is do YOU like it? |
Post Number: 63 Registered: Apr-04
Posted on i haven't gotten it yet. Should be arriving today. |
Bronze Member Username: Devils_advocate
Post Number: 70 Registered: Jul-05
Posted on Well then you'll find out real soon. I have the older SR500 and I think its great stuff, if that makes you feel any better. |
Post Number: 64 Registered: Apr-04
Posted on I like it a lot. I recommend this receiver to anyone looking to spend $300. |
