Help finding a receiver
Username: W00b
Post Number: 181
ok, i'm looking for a receiver that has low THD at high (low) impedences. My speakers are rated at 4ohms and I was looking at the HK-3480 until someone said that 0.2THD is noticable. I want the receiver to have a subwoofer out aswell. I was going to go with the NAD C162 / NAD C272 combo, but then i realized that it didn't have a subwoofer out anywhere in the configuration. My budget as of now is about $1200, but i would be willing to save up more for a better receiver or configuration. Please help! :-)
Username: W00b
Post Number: 182
Just a note, the configuration / receiver is for 100% music.
Username: Artk
Albany, Oregon USA
Post Number: 1243
The C162 doesn't have a specific sub out, so I use one set of the pre outs for the sub. Sounds far better this way than using a sub out. The key is that the C162 has 2 sets of pre outs. I really enjoy my C162 I'm sure you will too.
Username: W00b
Post Number: 183
wouldn't that mean that the whole signal is being passed to the sub? and wouldn't that mean that the sub is reproducing more than just the lows, i didn't think that was a good thing..?
Username: Devils_advocate
As long as you set the crossover on the subwoofer appropriately, you'll be fine.
Username: Artk
Albany, Oregon USA
Post Number: 1244
DA is correct Dustin. Then you just have one crossover working, the one on the sub. Cleaner and better sounding. Even if you had an AVR I would still use this method to hook up the sub, especially since music is your priority. Trust me Dustin get the components you want and don't look back.
Username: Rikmeister
Hometown, Pa Usa
Post Number: 30
did you look at a marantz they had the sr8400 at great prices. it is being discontinued.
