Subwoofer, under $200?
Username: Unpiled_acorn
Rockland, Ontario Canada
Post Number: 12
Suggestions anyone, need a hard hitting subwoofer, that'l please my gaming audio needs. Or should i just get 2 speakers instead with a budget of 400$
Post Number: 13
plz help!!!
Username: Jorge59
Rio de JaneiroBrasil
Post Number: 36
HSU STF-1 @ $299 direct. Try cheaper B-stock.
Username: Jamesp
Mansfield , TX USA
Post Number: 132
I am not sure if Costco in Canada is carrying The Klipsch 10 inch KSW sub but you may want to check. Nice little sub for $199 US at least in the US Costco stores in Texas.
Username: Petergalbraith
Rimouski, Quebec Canada
Post Number: 1005
In Canada, it's hard to do better than Hsu.
Read https://www.ecoustics.com/electronics/forum/home-audio/106107.html
The STF-1 is C$399.50 and so might be above your budget.
Username: Chitown
Post Number: 210
I wouldn't recommend that model of Klipsch. I saw it at Costco and did some research and there were a lot of people complaining that it burned fuse multiple times.
I have to agree with Peter about the HSU. I am so impressed with my STF-2. If you can afford it go with the STF-1.
I have a problem i need to know if there is a way to hook up 2 12s to my stock cd player without an amp.? If thats not possible please tell me of a place where i can get a cheap amp.I have 2 12s for $200 if anyone is interested email me at lilredneck0069@yahoo.com.
CARAUDIOMAN2005
Lanzar Heritage 124D 500RMS Watt each i got a pair for 180 CAD. Thoes are really good subs unknown but good.
