Capacitors?!?!?!?
Username: Sqeeks
Can some please help.....I know that for every 1000 watts you need I farad!
Im looking at buying the Kicker KX1200.1...this is over 1000 watts but I plan on running the amp
At 2ohm which drops it to 600 watts rms...what size capacitor do I need...is 1 farad enough or do I go bigger?
Username: Touche6784
Post Number: 494
wrong section kido. try the car audio forum. this is the home audio forum.
jake_needs_help_:D
christopher can you please look at my thread? thank you.
