EQ Button Question
Username: Occam
Post Number: 16
My stereo has a Bass EQ button. When should I use this. I notice no effect with only two smallish speakers.
Username: Edison
Glendale, CA US
Post Number: 789
The button lessens the bass - since your small speakers are not producing much bass to start off, you are not hearing any difference - but if you were to move to a bigger speakers with more bass, and you can use the button to cut the bass down - handy if someone is complaining about the loudness.
