SkieS Unregistered guest | Anyone ever heard of these? I have heard they are really good for the price, I'm looking at $140.00 for 2 sets of 10 gauge. If anyone has any expierence with them, please, let me know how they sound, or read any reviews, or know of a better deal. ![]() |
New member Username: MiltonPost Number: 4 Registered: Jul-05 | If it's speaker wire..then Home Depot will do just fine...pennies per foot for zip cord in the same gauge. |
Silver Member Username: ChitownPost Number: 197 Registered: Apr-05 | Keep your $140 for a real upgrade on your system. Go to Home Depot. |
SkieS Unregistered guest | I need one end spade and the other end banana on both sets, does Home Depot sell those? |
Anonymous | Not sure, but if not Best Buy or Radio Shack probably can help you. |
Anonymous | Or you could go to: http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=100-156 50' of 10 ga. for $35.90 and buy the spades and banana's from them as well. Banana plugs: http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=091-330 Spades: http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=095-671 Just a few ideas you might check out. |
