Blown receiver question
I moved into a new house that had pre-installed outside speakers that were wired into the house. I hooked up my receiver and they played fine for about 30 minutes, then the receiver cut out. Now it won't even turn on, I checked the only fuse I could find inside (right by where the power cable comes in) and it looks OK. Any idea what the problem may be?
