Unregistered guest |
Posted on If so, let me know what the lowdown is and what they are worth. Does the name Amagna 1912 mean anything also? |
Bronze Member Username: Ornlu
Post Number: 38 Registered: Apr-04
Posted on Did you mean to go to the car audio forums? And alpine subs are crap. |
Posted on Yes, and should you be on the computer little boy, or did your momma forget to set the parental lock? Didnt your parents tell you to say something nice or not say anything at all.... |
Silver Member Username: Touche6784
Post Number: 483 Registered: Nov-04
Posted on go to the car audio forum |
Posted on Thank you for your non-sarcastic help. |
