Sony PS-FL1 - needs an adjustment i think?
Hi all!
Well I pulled out all my oldies and was playing them on my old sony turntable.
Problem is i have to manually put the stylus down on the record, otherwise it just slides right off. I guess it's off a hair, because once it starts playing it's fine. It just doesn't automatically start up good anymore. I have to coax it.
I don't know if there is a way to adjust the arm, or maybe it needs a new stylus not sure...hope you can help thanks
