Bookshelf / Pre-owned
Username: Occam
How about good bookshelf speakers in the $150 to $200 range. I looked at Infinity's Primus series. What about Fluance? Wouldn't it be a good idea to buy high quality pre-owned?
Mc_X_iT
Personally I would go with a pre-owned pair. Better bang for you buck. I have seen Paradigm Studio 20's sell used for as less than $250, and they are a great speaker. Depending on where you shop you may also be able to squeez a pait of Paradigm titans into you budget if you decide to buy new.
Username: Donaldekelly
Washington, DC Usa
Post Number: 271
Studio 20s for $250?!?
Where?
Username: Eyeswideshut
Abubala , Ababala The Occupation
Post Number: 34
Hell, I'd even buy those pieces of junk for 250.
Washington, DC Usa
Post Number: 272
Shut up Alfonso
Post Number: 37
Suck my balls Donald.
