What are the best speakers for a laptop, under $60?
Tyler J
I need some speakers for jamming to some music and watching some dvds. Post the best options! Thanks for the help!
Do you want a subwoofer (2.1 system) or no (2.0 system)?
Username: Frostyda9
Calgary, AB Canada
Post Number: 19
I use the Altec Lansing ATP3 system (2.1) and it's decent. It won't shake the walls or amaze you with detail, but the down firing drivers in each speaker give you a sense of spatiality, somewhat. They're also pretty small, which is nice. They are just a tad over your budget, but if you shop around you might find them for that.
Randomness Personified
You might try to find a set of Logitech z-2200 or z-2300 on eBay.
