Outlaw 770 + 950 With Bayaudio speakers
Username: Spazzbecker
Hi Guys and Gals :-)
I have a set "x5" of Bayaudio cube speakers See link http://www.bayaudio.com/cube.html also running 2 Sonance 12" subs I'm researching the Outlaw separates, has anybody ran them with the Bayaudio and Sonance subs? I listen to 60/40 Music/movies.
Thanks
Carl
Username: Gman
Mt. Pleasant, SC
Post Number: 303
I doubt you'll find any people on this site with Bay Audio cubes. As long as your Sonance subwoofers are self-powered, getting the Outlaw Audio combination is undoubtedly overkill for the BayAudio cubes. Those 8 ohm speakers are designed to perform well on any mid-price receiver.
If the Sonance subwoofers are passive, you might consider getting 2 Outlaw Audio monoblock amps for them and then hooking everything up to a good mid-priced receiver.
But if you feel like spending the money on the Outlaw combo it will certainly drive the speakers easily with a lot of power left over. Just be careful not to drive the speakers into heavy distortion, as the 770 has enough power to fry them.
Hi Gregory
Thanks for the reply, do you have any experience with the bayaudio speakers as I have just got these? What mid-price receiver would you recommend for a combination of Music every day and movies at the week end?
Thanks for any advice you have
Carl
Username: Gman
Mt. Pleasant, SC
Post Number: 306
No experience at all. I just read their information, their specs, their power handling ability, etc.
Are those Sonance subwoofers self-powered?
What size room do you have? Do you already have HDTV and a dvd player? If so, which dvd player?
I ask these questions as the hook ups and performance of some dvd players could be better with different receivers. Such as, if you had a Pioneer Elite 47AVi I would recommend a Pioneer 55TXi receiver for your system, to take advantage of the firewire (i-link).
You might want to buy one of the NAD models, from the T753, T763, to T773--depending on how much money you want to spend and which features you want.
Another good receiver is the Harman Kardon AVR630 that is available at Onecall.com for $718.
If you want to diddle around with a lot of different DSP's whilke watching movies you might want a Yamaha 2400. It doesn't have the superior amplifier sections of the NAD's, HK's, or the PE 55TXi's, but it does have an excellent preamp section.
