Receiver Recommedation $500
Username: Bman3
Just finishing up a renovation and need a receiver for my home theater/music (will use about 70% for music). Want to stay under $500 and have looked at Denon 885, Yamaha 1500, Marantz 8400 (ebay has these all within price range except Marantz is a little more). Would be very interested in opinions on best choice amoung the three AND also if you have any others that you think I should consider.
Thought very much appreciated!
Username: Sem
New York USA
Post Number: 496
I haven't heard the Marantz, but have heard good things about it.
As long as you're looking at ebay, this may be something to consider:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=14981%26item%3D5786640419 %26
Its a couple model years old now but, provided its it good shape, should sound spactacular. I believe at least a couple regular posters here either have this receiver or did at one time.
Username: Paul_ohstbucks
Post Number: 1571
Brian,
Based on your price range, the Marantz looks like a pretty good deal if you dont mind buying on ebay.
Otherwise, I'd recommend the Yammi1500.
Username: Riches1
Atlanta, GA US
Post Number: 171
Good recommendations above. The 8400 would be a great deal if you could get one that fit your budget. I would also look at Harman Kardon. (That's from a current Denon 3805 owner who used to own H/K)
Username: Edster922
Post Number: 1186
The 8400 would be great if your budget agrees, also look at Harman Audio on eBay, you can get some great deals with full original HK warranty like this:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39794%26item%3D5787617731
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39794%26item%3D5787886941
Username: Edison
Glendale, CA US
Post Number: 744
Onkyo TX-LR552 !
http://www.bhphotovideo.com/bnh/controller/home?A=details&kw=ONTXLR552&is=REG&Q= &O=productlist&sku=348603
Username: Edison
Glendale, CA US
Post Number: 745
Try to hear this one - you will like the warm smooth sound - like an upscale piece. Now we all can have a luxurius sounding surround sound.
i need really really badly badly the guide how to set up my pansat 2500a version reciever.
Somebody set it up for me and he is gone now. Any help plz plz plz
thelion11@cs.com
