New member Username: DishstreamPost Number: 2 Registered: Feb-05 | Hi: Hello evryone, I am anew bee and,I have a question, say I want to make a 200w bookshelf speaker with a tweeter and a woofer (for midrange and low), how we can divide this 200w (rms) of power b/t tweeter and woofer, should they be of equal power, or tweeter can be of 50w (rms) and woofer of 150w (rms). Also when we will connect the 8ohms woofer and tweeter in parallel with one of the amp. channel,the combined impedencewill reduce to 4 ohms, but amp. needs for 8 ohms imedence per channel. |
Silver Member Username: PetergalbraithRimouski, Quebec Canada Post Number: 907 Registered: Feb-04 | You can't just connect them without using a crossover to dispatch the proper frequencies to each driver. There's much less power going to the tweeter in typical situations. I don't know how much, but if I had to guess I'd say a ten to one ratio. |
Silver Member Username: EdisonGlendale, CA US Post Number: 737 Registered: Dec-03 | Post it here, and you will get more responses. http://www.diyaudio.com/forums/forumdisplay.php?s=b4b963b973c55cad037e29d8d70937 be&forumid=6 |
Silver Member Username: EdisonGlendale, CA US Post Number: 738 Registered: Dec-03 | You might want to make a project on the web - with a X-over design that is tested. This is easier than designing your own. http://www.speakerbuilding.com/diy/ |
Silver Member Username: Timn8terSeattle, WA USA Post Number: 294 Registered: Dec-03 | This is a fairly common question. It demonstrates that you need to do some serious research before you attempt loudspeaker design. James is right. You'd be much better off building a proven design than trying to build something using trial and error. If you are determined to create your own design you'll need to be able perform measurements. This means proper measurement equipment. This site has some interesting information. http://members.aol.com/pjay99site/speakerhome.html You'd better hit the books too. http://www.amazon.com/exec/obidos/tg/detail/-/007069429X http://www.audioxpress.com/bksprods/bkindexldesign.htm |
