An issue with the THX optimizer
Username: Urlacher
Post Number: 31
when I play the audio tests for this it says the sound is coming from a different speaker than it should be. Like for example when it goes on center channel you hear the noise out of the left speaker. This only happens with the optimizer. I have a lens cleaner with an audio test on it and it says the sound is right where its supposed to be. Any idea whats up with the optimizer?
Username: Dmwiley
Post Number: 888
Sounds like a defective DVD title.
