Yamaha CR - 450
Stuck In 74
i've got a vintege receiver that i'd like to connect my laptop to. my jacks are all used by other equipment, so i'm wondering if there is some kind of split i can use to connect two things to my aux jack? also, is there specific cables that i need to consider using with such an old receiver?
Username: Edison
Glendale, CA US
Post Number: 749
Go to a radio shack and explain what you want to do, and they can get you the stuff.
You don't need a special cable - regular ones will do.
If you are looking for good sounds from your computer, you can upgrade the sound card to waveterminal u24 off ebay for $160.
Computer can make really good source - less jitters than even an upscale CD player.
Get these free programs for good sounds on google:
EAC (copier)
Foobar (player)
