Speaker wire ? please help
Username: Jayosa
Post Number: 12
have a harmon kardon avr330 reciever and athena asb2 bookshell speakers...my reciever is within 10ft of the speakers...i just bought 16 gauge speaker wires from home depot and the music sounds good ...would i get even better sound if i would have bought the 12 gauge from home depot instead of 16 gauge...somebody told me the 12gauge wouldnt make a diffrance because its only 10ft...he said 12 gauge only makes a diffrance only is the cord was very very long ..is this true ..please help..
Username: Shahrukhd
Mumbai, Maharashtra India
Post Number: 65
I agree with your friend. That's all I'll say about that.
However, if you're happy with the sound, leave it at that. Don't go spending more cash on something you're not sure will make much of a difference (in this case it won't, IMO).
I am installing in-wall speaker wire and I want to use the existing holes in the studs that the 12/2 electric wiring is snaked through. Will this cause a lot of "Noise"? Also, what gauge should I use? If you have any other pointers I would appreciate it. Thanks
Username: Jan_b_vigne
Dallas, TX
Post Number: 4451
Check local building codes. Most codes do not allow the speaker wire to share the installation location of the AC wiring.
kfaria
Let's assume that code allows for it
Username: Eramsey
South carolina United States
Post Number: 247
Never assume anything with building codes!
