Denon avr2805,connecting sub
Username: Walter
i have a sub that needs two sets of speaker outlets to connect to, out of the nine what ones should i use. the sub is a niles psw8. any help is welcome
Username: Chitown
Post Number: 150
Walter you probably have a passive sub that requires you to put it in between the two speakers and the amp. I would connect them the front L&R.
Or you may want to look at the active/powered subs out there.
www.hsuresearch.com
has some nice ones. You can connect thes to your LFE connection on the back of the 2805
