jimrobertsusa Unregistered guest | Is anyone using this receiver? How loud do you push it, I didnt want to push it too hard. I get it up to -10 and it doesnt seem loud enough, can I push it further? It also gets very hot, is this normal? Thanks |
Gold Member Username: MyrantzThe Land Dow... Post Number: 2059 Registered: Aug-04 | +18 I think is the maximum if you don't increase the loudness in the speaker/surround set-up variables. Make sure the unit has plenty of breathing space around it and don't use low impedence speakers (6 - 8 ohms okay). I have an SR-7300 and in hot weather I use a small low voltage computer fan to draw air from the top vents. It's quite and works well. |
jimrobertsusa Unregistered guest | ok so going past -10 isnt a bad thing then |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 1013 Registered: Feb-05 | I never went to -10. I listened to movies at between -20 and -16. I did have the individual speakers calibrated 0 to + with none below 0. |
jimrobertsusa Unregistered guest | hmm thats interesting. When listening to music -20 seems pretty loud, but while watching movies the sound set at that same level is drastically reduced |
Silver Member Username: ChitownPost Number: 146 Registered: Apr-05 | Jim I have noticed that the audio quality of the movies is drastically different and the ones that are done well produce more varying levels of sound within the movie. Last night as I watched parts of LOTR: Return of the King, the high battle sounds were really lound while some conversations were low, even though I didn't change the dial at all. (I have an SR8400 btw) |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 1020 Registered: Feb-05 | With music I never went above -20 jim. I was talking about movies in my previous post. |
jimrobertsusa Unregistered guest | I understand what you meant Art, and I usually stay around the same level as you. What I meant was if I keep the level at say -20 for music, then switch it to a movie keeping the volume at the same -20, it sounds significantly less loud |
Gold Member Username: MyrantzThe Land Dow... Post Number: 2070 Registered: Aug-04 | Our room is rather large (24'x20' with raked ceiling sloping 18' to 10'). With the Sr-7300, movies are generally okay on about -16 and music varies around -16 to -25 (average -22) for decent listening levels. Regardless of the jibes, I recommend using an spl meter to set all levels. Here is tips on how to do so: http://www.audioholics.com/techtips/setup/loudspeakers/settingspeakerlevelsdista n.php Also, you can set a higher level for your surround modes in the setup. Actually I use the receiver's decoders for movies and slightly different speaker adjustment levels on my universal player to accommodate better (more optimised) levels for sacd and dvd-a sound. |
Silver Member Username: PetergalbraithRimouski, Quebec Canada Post Number: 895 Registered: Feb-04 | I guess it would help if people reported their speaker efficiency as well, so we know how many dB to adjust for. |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 1029 Registered: Feb-05 | 89db, at that time I had Paradigm Monitor 5's. You are right jim and you will find that same situation with any AVR. There is nothing wrong with it. All is well. |
jimrobertsusa Unregistered guest | Thanks Art Now do you know if I have an external amp for the mains using the pre-outs of the sr5400, will this help to reduce the amount of heat the unit produces? |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 1031 Registered: Feb-05 | It probably will. My new NAD barely gets warm with external amp on the front 2. The Marantz was warmer but not as warm as it was before I started using the external amp for the mains. |
jimrobertsusa Unregistered guest | Sorry for asking but I a really dont have any knowledge on these matters. Currently I have my sub connected via the sub out on the receiver. If I use an external amp for the mains, does the sub stay connected to the receiver the way I have it now? |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 1035 Registered: Feb-05 | Yes, unless you add a 2 channel pre amp to the mix. We won't go there for now. |
