Thread | Last Poster | Posts | Last Post | |
Archive through September 02, 2005 | bent | 100 |
Gold Member Username: Project6Post Number: 3750 Registered: Dec-03 | Don't think i didn't try![]() Some of these poor souls have no idea what they are geting into. |
2 computers? Unregistered guest | I just had a simple question. I recently bought and ipod, and I have two apple computers. I waswondering if I could upload songs from both computers? I ak because, when I try, a message comes up that says something like "would you like to replace all previous songs for these songs?" or something. Should I just ignore it and continue, or what!? |
Gold Member Username: Project6Post Number: 3762 Registered: Dec-03 | The prompt should tell you everything you need to know. MAke sure that the update on your iPod is done manually and not automatically. This will ensure that you control which songs are put in or taken out. |
help me Unregistered guest | PLEASE HELP ME! my ipod usually always worked but ive come to the conclusion they suck...im plugged into the usb port and it no longer will appear for me on itunes so i cant listen to it on mi p/c |
SEsenay Unregistered guest | I HAVE A BIG PROBLEM WITH MY IPOD MINI IT WAS WORKING FINE UNTIL I LET IT RUN DEAD AND I DID NOT USE IT FOR A WHILE THEN NOW WHEN I PLUGED IT IN TO CHARGE IT SHOW A SCREEN WITH A PICTURE OF A SOCKET AND AN ADAPTER. pLZ HELP |
Gold Member Username: Project6Post Number: 3872 Registered: Dec-03 | your internal battery is dead. Send it in for a replacement, because it will not hold a charge. Do not ever let a lithium ion battery drain all the way. It will shorten its lifespan considerably |
Jade Unregistered guest | HEY! i connected my ipod to the computer and a sign came up on my ipod saying *DO NOT DISCONECT* but now my songs are unable to be updated because the ipod sign is not on the libary please help! ??? |
Gold Member Username: Project6Post Number: 3897 Registered: Dec-03 | Hey yourself! This topic has been covered. Do a search and do some reading. If not go to the apple.com website. |
Brodie Unregistered guest | Weird iPod Mini problem. I recently updated to the iTunes to the 4.9x release that supported Podcasting, but once the update was done ITunes recognizes my 6Gig iPod Mini but it won't transfer tunes to the iPod or delete the tunes on the iPod. Here's the kicker, ITunes says that the iPod has 58.8 Gigabytes of space with 37 Gigabytes used. I just (last night) updated to the new ITunes 5 and the latest iPod updater. No change. Still can't get iTunes to recognize this as a 6 Gig iPod Mini. Any Ideas? BTW, I'm using a USB connector, and I can control/update the iPod from my other PC which is still running the older versions of the iTunes/updater software. So the iPod and cable are OK. |
Unregistered guest | Hi i have an ipod i had to reset it today because the song wouldn't play. Now it has a sad face with x eyes. I have dropped it once and now it is like that. Can you help me |
bent Unregistered guest | Brodie . ... . You answered your own question |
bent Unregistered guest | Jade your ipod is dead You may have damaged it when it dropped hdd is probably fried call apple |
New member Username: Smudger1897WorcesterEngland Post Number: 1 Registered: Sep-05 | can i transfer my library from my pc to my moms pc as this is the only one with internet access, when i down load a song so when i try to add a downloaded song i can only do it by replacing the whole of my existing library... |
Unregistered guest | I recently moved with the best friend and I dont have my computer anymore so i am using her's. When i connect my ipod it wont let me put new music, do you know why? She had already set up her ITUNES. |
New member Username: Ibo07Post Number: 1 Registered: Sep-05 | hi my ipod wont turn on ive tried everything.. do you think that i will have to get a new batery??? when i conect it to the computer nothing comes up. ive kept it in charge for 24 hours ive reset it nothing happen. wat do you guys think?? |
Gold Member Username: Project6Post Number: 4036 Registered: Dec-03 | angie, go to apple.com and do a search on tech support. Look for how to use multiple iPods on 1 PC. |
Gold Member Username: Project6Post Number: 4037 Registered: Dec-03 | ibrahim, looks like you need a new battery. How old is the iPod? Did you let the batteries get exhausted? If you did, that is a problem, you cannot let your iPod's battery run out, you have to constantly charge it. |
Anonymous | Sorry to add yet another question- I charged my ipod mini using the USB plugged into my computer and then when I turned it on to use it after it was fully charged all my music had disappeared. It has done this once before but after being turned off and left for a while, the music reappeared. It's now been over 24 hours though and no such luck. Any idea why or if I can retrieve all my music? Am reluctant to copy it ALL back on if possible. |
Unregistered guest | ok... I wont go into details, for fear of my reputation, i know i screwed up and i dont need anyone else to tell me that... Anyway i did "something" and now all that appears is the apple logo. it will not connect to a computer. no program will recognize it. Im wondering if any program will manually recognize it and re-format it, or install a different version of it. Apple has nothing to do this so i was wondering if anyone has done something like this and found a program or method capable of resetting an ipod. PLEASE HELP, i love my mini, and they DISCONTINUED IT!![]() |
Unregistered guest | please help me my ipod mini wont turn on. not even the apple is coming up, it said it had a low battery when it showed it was half full and now it wont even turn on when i plug in to the computer and iv tryed resetting it and it isn't responding please help me its my baby i love it |
bent Unregistered guest | ZebZ Use a HD app like disk warrior or disk utility or if your on pc find a drive utility and reformat the Ipod .. . its just a portable drive. Even if its not recognized by itunes it should be recognized as a drive connected to your computer. Then reinstall the new software. And you need to describe "Will not connect to a Computer" better thats too vague did you jam something in the socket or are you stating that a computer wont recognize it as a plugged in device via Usb or Firewire. |
Bearman Unregistered guest | I've just run an update for my mini, everything seemed to go ok then a screen came up telling me to conect to the mains adaptor. The same screen appeared on my mini, so i did exact' what it said but everything seems to have frozen and I can't access anything. tryed a reset but no joy. Help........!!!!!!!!!!!!!!!!!!! |
princess emma Unregistered guest | i have heaps of songs on my ipod mini and i used to play music uiz all the time and now it just won't let me play it, it comes up with error, no songs found HELP plz |
princess emma Unregistered guest | i have heaps of songs on my ipod mini and i used to play music quiz all the time and now it just won't let me play it, it comes up with error, no songs found HELP plz |
Unregistered guest | hi everyone, i have a 20 gb ipod, and mine works properly i just updated the new itunes 5. my buddy has no idea how to use his ipod mini, since it was gift he had his ipod mini set up by another friend of his. he has like 200 hundred songs he wants to get ridd off and i offer to help laso i wnated to put some new good song in his ipod mini, i thought io coulod use my own itunes in my computer and that my computer and itunes will recognize the ipod mini, but they are not. the computer recognizes a drive e, but the itunes does not and a message appears saying the nex:"this ipod needs to be reformatted for use on your PC. click on the buttton below to run the ipod uppdater taht will allow you to reformat or restore your ipod" after that a message appears and it says updating and fter it does it asks me to restore which it will erase all the music, which i don't intent to do so i quit it and noithing happens and i then i can't do anything about itunes won't recognise it an even this other progarma i have that is called ephpod that lets you put sonhs and extract songs from ur ipod doesn't read it neither..... PLEASE some help |
New member Username: Ipodfan1Tulsa, OK Us Post Number: 1 Registered: Sep-05 | hi everyone, i have a 20 gb ipod, and mine works properly i just updated the new itunes 5. my buddy has no idea how to use his ipod mini, since it was gift he had his ipod mini set up by another friend of his. he has like 200 hundred songs he wants to get ridd off and i offer to help laso i wnated to put some new good song in his ipod mini, i thought io coulod use my own itunes in my computer and that my computer and itunes will recognize the ipod mini, but they are not. the computer recognizes a drive e, but the itunes does not and a message appears saying the nex:"this ipod needs to be reformatted for use on your PC. click on the buttton below to run the ipod uppdater taht will allow you to reformat or restore your ipod" after that a message appears and it says updating and fter it does it asks me to restore which it will erase all the music, which i don't intent to do so i quit it and noithing happens and i then i can't do anything about itunes won't recognise it an even this other progarma i have that is called ephpod that lets you put sonhs and extract songs from ur ipod doesn't read it neither..... PLEASE some help |
Lydz Unregistered guest | hey, my ipod might have a problem, but im not that sure. my ipod has 207 songs, yet when i try the music quiz, it says "error, no songs found". What am I supposed to do there? please help... >.< |
Orpheus Unregistered guest | My main drive is d: The apple site says that the updater won't work if the main windows drive is not c: I updated on another machine but itunes won't recognize the ipod on the machine with the d: drive. I've had this problem before but after rebooting the ipod, it is eventually recognized. Unfortunately, I forgot what exactly I did. Any suggestions? Thanks. |
Orpheus Unregistered guest | I'll answer my own post for the benefit of those having the same problem. In control panel, administrative tools, assign a drive letter to the ipod drive that is a higher letter than the boot drive. Then run the updater and restore the ipod from the machine with no c: drive. The ipod will then get recognized by itunes. |
sarabee Unregistered guest | my ipod mini is being retarded. when i reset it, it shows the apple icon, then the sad face, and then settles at the picture of the charging battery (but minus the animation). its stuck on that picture most of the time. my computer won't recognize it either. i'm really at a loss of what to do with this stupid thing and i've looked on the apple site and haven't found anything. please help! |
Gold Member Username: Project6Post Number: 4120 Registered: Dec-03 | actually the sad face is telling you that the iPod is dead. It needs to be repaired, there is nothing you can do to fix it. |
Unregistered guest | I was charging up my iPod mini and added a few songs, then ejected my iPod out. All of a sudden, the computer recognized the iPod again, but I pulled out the wire as it happened. Now my screen is frozen with the screen that says "DO NOT DISCONNECT." I've tried to reset it by pushing the menu+select buttons, but so far that's done nothing. If anyone knows of anything I can do, please let me know!! |
Worried Unregistered guest | hi.....i hadn't listened to my iPod Mini for about a week. So I turned it but instead a pic of a sick iPod and an exclaimation mark showed up on the screen then it turned off. I know there's something wrong with it but I don't know what........PLEASE HELP |
New member Username: MsipodPost Number: 2 Registered: Oct-05 | can anyone help me? i cant add songs or update or factory restore my iPod, and whenever i delete songs, they are still on my iPod, except when i click one of the deleted songs, it doesnt play, and i dont want the deleted songs to show up. whenever i run the updater, it says iPod internal manager error. my iPod is still functioning, except for those things. plz help me by here or at aim AIM: doomofeternity thx |
jess 2005 Unregistered guest | when i plug my ipod mini into the computer it doesnt recognise it so i cant put any songs on there. i have got songs on there already becuase i used my friends computer when i didnt have one myself anyone no wot the problem is? thnx |
Austin W Unregistered guest | dude ok first of all my ipod will NOT load any of my music. it wont even say thats in connected in itunes. but it still makes the noise saying that it is connected to the computer. and i went to the apple website and it said to redownload itunes so i did and it didnt help at all. i really want to use my ipod buti cant if i cant get my music onto it so PLEASE help. |
Austin W Unregistered guest | oh yeah its an ipod U2 edition |
New member Username: OverthemoonPost Number: 1 Registered: Oct-05 | I have had my mini ipod for 10 months and all of a sudden when I log onto the music store it won't display any songs when I log in a search. The top part of the screen (i.e. the album covers) appears but no songs appear below it. I can't even download the free songs 'cos they don't show up! What's going on? |
molly b Unregistered guest | nancy s, i had the same problem today. im thinking that its maybe just an itunes malfunction, but im not sure. and also, my computer will not recognize my ipod either, and i have had it for about a year. anyone know how to help? |
New member Username: OverthemoonPost Number: 2 Registered: Oct-05 | Thank goodness my computer still recognizes my ipod (knock on wood) but I haven't been able to search for or download songs for over a week now. If it's an itunes glitch it's lasting a long time. |
Unregistered guest | can any one help... i have had my ipod mini for about 8months i think, and love it. But last week i re-installed my winXP computer therefore erasing all my itunes songs. I kept my songs on my ipod. Now my pc cant find my ipod when i try to reinstall itunes and ipod updater, it charges fine from my usb, even the 'dont disconnect' dosnt come up anymore. thanks for any help... |
gia Unregistered guest | Hi! please help me! I found that my computer (after reinstalling windows) feels the iPOD and shows the hard drive icon on resources but I am not able to open from there and not even from iTUNES or iPOD updater. thanks |
dafilanegro Unregistered guest | i am also having the same problem as everyone else. my ipod is connected to my computer but when i click on itunes preferences it says there is no ipod connected |
eleanorreeve Unregistered guest | help, my ipod turns on but won't charge. When i plug it into the main charger, or the usb, it won't appear on my computer but it does play -but it won't charge and it's got next to no battery on. what do i do? |
chris_webs23 Unregistered guest | i have fixed my ipod mini, i posted not long ago wiv a common problem. What i did was took the cd i got with the ipod, and basically installed it on my mates pc, it worked on there... then i reformatted it and now it is fine on my comp. If u dont have the cd download itunes 6.0 and the ipod updater on someone elses comp. hope this helps.... |
New member Username: Fanzie21Sacramento, CA USA Post Number: 1 Registered: Oct-05 | Hey, I have a ??? When I turn on my Ipod the apple face comes on...but then......there when the apple face comes off another face comes on a ! nd a weird crash face. anyone kno how to fix it??? I sure dont I tried restarting it and everything it just wont work. can someone tell me how to fix it please thnx! |
Gold Member Username: Project6Post Number: 4182 Registered: Dec-03 | Greg, You have a bad hard drive. Send it in for repairs. You can check apple's website and find out what those icons mean. |
Oren Unregistered guest | I need somebody's help!!! I bought an iPod mini, and I thought it will say everything on the package. But it doesn't!!! And I don't get how to put songs on it....Oh my god I shouldn't have bought it....But I thought it wil be easy!! Ok,now I'm talking to myself.See how much I need your help?!?!?!? Thanks anyone who wasn't scared off by me and might help... |
simmo Unregistered guest | hi all, my Ipod mini connects to the computer fine, it recharges the battery and displays the 'do not disconnect' message as its connected to the computer via usb. However, my problem is that whilst descriped above, a padlock symbol is shown and when I disconnect the thing, the apple logo is displayed briefly, then the menu comes up, still with the padlock logo displayed and none of the buttons work. Obviously ive checked and made sure the hold swith is off, but I just can't seem to use the buttons!!! This being the case, I can't even reset the thing! And yes I've pulled it apart and checked the wires are all plugged in. Any ideas anyone? I thank you in advance and your help is much appreciated. |
Unregistered guest | HELP!!! PLEASE!! I just got my ipod last night, and I have songs from other players...some of the songs are saved in windows media player...those songs were updated into the itunes library and it updated my ipod mini. but i just downloaded limewire to add new songs...itunes is recognizing it because it made a playlist for it, but i cant get those new songs onto my ipod! how do i do it?!??! Please help! |
Nicole Michelle Unregistered guest | Oren...you need to install itunes |
Unregistered guest | ::sniff:: PLEASE HELP!! ![]() Scary prob: I dropped my mini n it froze so I let the battery drain for 24h like they say to on Apple's website - but when I connected it to the PC it showed an unanimated battery for a few mins, then the Apple logo appeared and it's still there... NO Exclamation - just the half-eaten apple... when i reset it, it shows the apple again, and the dumb logo just sits there... my computer won't even recognize it ![]() |
Austin W Unregistered guest | so when i plug in my ipod into my computer it SAYS that its loading all my music off itunes into my ipod but when it says ints finished by ipod freezes up. then i restart it (menu+select) and none of my music is there. what do i do? |
Unregistered guest | HELPPPPPPPPPPPPP !!!!!!!!! well i got a used ipod .. and i managed to erase all the songs off the ipod library/folder .. the problem is -- it says its still using 2GB!!! but there is nothing on it ... someone please help me ..... |
bent Unregistered guest | Nicole Michelle . . . find your actual mp3 files on your hard drive and not the alias in itunes and drop them in your ipod. The limewire tunes you have are not in your itunes lib thier in your shared files on your hd. Serzz .. .. Restore your ipod to factory settings with Ipod Updater, it will zero out the drive on your ipod and restore the drive. Austin . . . same thing Restore you ipod put the latest drivers on it via Ipod Updater, also try manually placing your files on your ipod to see if they load. Unclick the option for loading files automatically in your ipod options and choose manually load files. Then just drag and drop the mp3 to your ipod icon in itunes. |
nump Unregistered guest | my ipod is messed up and it just shows the apple sign when i reboot it |
the jacka-mob figaz,thizz nation Unregistered guest | i really need help fast. i dont know what to do next.i've tried to drain the battery,plug it into the computer.i just dont know what to do anymore |
queenbee Unregistered guest | ok it seems as if i'm having the same type problem as some of you...MY IPOD WILL NOT TURN ON FOR THE LIFE OF IT!!! what do i do. i tried holding down buttons and plugging it into both the pc and the wall. i'm freaking out here? is there anyway it picked up a virus? or whats the deal? help!!!! |
Unregistered guest | I have read most of these posts and I think they have answered my question but I just want to make sure! One day i went into iTunes and all of my 409 songs were gone. They are all still on my ipod and I don't want to have to borrow all my friends CD's again just to get the songs. I was thinking of downloading an Ipod music liberator! Will that solve my problem? Thank-you |
Davis Unregistered guest | Hey, I need some serious help. Ok, I've had my iPod mini for a couple of months but this only started recently. When I try to play songs on my iPod, the sound gets all messed up and you can barely hear it. The volume can be anywhere and its still all messed up. This has been happening for two weeks now. Before, it was just when I hadn't charged it, but now it happens all the time, even when it has just been fully charged. I have dropped a few times in the past, but not recently enough for me to believe that dropping it caused this damage. I can't think of what to do so please help me soon. |
ReallyConfused Unregistered guest | I have an iPod nano and I reset it and put on some songs and then once it told me it was ok to disconnect, the screen has changed from colour to black and white and there is a picture of a folder and a triangle with an exclamation mark in the middle and below it says: www.apple.com/support/ipod BUT when I attempt to reset it again the same thing keeps happening! |
Unregistered guest | I'm sure it has been posted earlier(possibly) but I will take a stab at it anyways. I also have a problem with my Ipod mini. It just doesn't work. More specificly it emits a beeping sound whenever it has a charge and is disconnected. It will still charge in usb and firewire, but it will only activate if it is reset while connected by firewire. Then it works as an ipod should. When it is disconnected the screen goes blank and no longer works. What gives? |
Unregistered guest | hey, i kept my ipod connected up to my computer and then turned it on, then when i went to my itunes all my songs were gone, i dont have any songs in my library, i dont keep then anywhere but in my ipod, ALL MY SONGS HAVE BEEN DELETED, HOW DO I GET THEM BACK!!!!!!!! please help if possible! |
lumus Unregistered guest | can any budy help me with my ipod mini plz |
hallie Unregistered guest | Vexed and Perplexed! I upgraded itunes recently when prompted. THen I connected my ipod, it said my library was larger and would select songs for me. I said no. Later when I went to use the ipod it was empty! Now when I connect my 4GB mini ipod to the computer, it says updating complete, but when I eject my ipod, no songs have actually been transfered, it is empty. Then I restored the ipod to factory settings and updated it. Then I manually transfered songs by clicking and dragging in itunes. They appear and play under the ipod icon in itunes, but once again, when I eject by clicking the button, there are still NO songs or playlists on it. I am not getting any error messages. It seems to be working fine, except that I can't seem to load songs on it. Please help! |
hallie Unregistered guest | Okay... I just noticed this as I continue to fiddle with this thing... EVERY time i connect to my computer (via USB), a box pops up and it asks me to give my ipod a name and to register. If I click cancel, it acts fine and I can carry on with itunes. Just thought I'd mention that as well... Thanks - |
angel babe Unregistered guest | plez help ma mp3 won't work and when its off and plugged in it still won't turn on but says starting..... and ive tried to press play, menu and both 2gether plez help |
angel babe Unregistered guest | by the wat its easy tech |
Adam108 Unregistered guest | Hello, I have an ipod photo 20gb. I dropped in water two days ago where it remained for 2-3 seconds before I pulled it out. I freaked out a bit and pushed the click wheel and switched it to hold (as I know I should not have done with water inside of it). Since then, I have let it rest, taken it apart, blow dried it, reassembled it, charged it, reset it (menu/select) restored it through ipod update, and loaded songs onto it. The ipod will charge, and I can sync with itunes and manage songs (load and erase) when connected to my mac and itunes. It will turn on when I switch it to hold and the light will come on when I switch hold off. It will respond to a simultaneous menu and select button pressing. It will not respond to scrolling or clicking to view the music files or play music. There is no audible when the click wheel is pressed. The only response from the click wheel is when I reset (with menu/select). I feel like I am so close to a revived ipod. How can I get my click wheel to respond? Thank you, |
New member Username: Den8grisRodvigDanmark Post Number: 1 Registered: Nov-05 | hei.. can anyone help me.... its about my ipod when play music the batteri lasts like ten minuts max and then when i plug it in the adapter it says the batteri is full... what do i do? |
Unregistered guest | OK i have an ipod mini and when i hook it up to my pc the ipod sign wont come up and then itunes says that it cannt read the contents of mi ipod and that i have to use the ipod software application to restore mi ipod to factory settings!!!!! two questions. 1) where is the ipod software application 2) will it erase mi itunes if i restore mi ipod to factory settings?!?!?! plz PLZ email me at hell_girl_xox@Hotmail.com or xox_bitter-sweet_xox@hotmail.com please help me!!!!!!!!!!!!!!!!!!!!! |
Anonymous | my ipod nano will update with songs and charge but then when it is done updating it will stop charging.It also wont charge when i turn it off.Can some one please help me !!! |
Unregistered guest | Hi. My iPod Mini is transfering is songs automatically, but about a 1/3 of the way thru, it stops. It lags and the little sync icon at the top left of the iPod Mini, stops then starts. Eventually when it finishes, after about a day(!), I disconnect in the usual fashion to find that the songs arent there! I did notice that the playlist names were there tho! Im really annoyed cos i love my mini! Can anyone clever help me? P.S. Ive done all the obvious restore, reinstall software and that kind of stuff! Thanks very much! Old Ag3nt <e.support@hotmail.com> |
Anonymous | I have only had my ipod mini for awhile, and i try to turn it on and it does and the light comes on and all, but no words or songs or anything shows up. I can guess which each "click" is and get to songs but i dont want to do tha cause it's soo anyoig! Please help me. What do i do?? |
Anonymous | I have an ipod mini adn when i turn it on the light comes on, and if i randomly click things i eventually can get to songs but i need to know how to get the words, and songs, and EVERYTHING else to show up on the screen. Hope yall undertstand me, PLease help. Its sooo annoying and frustrating!! |
Unregistered guest | I have an ipod mini for a month now and it has been working fine so far. Today though, i left it home because my battery was completely dead (like always since i keep forgetting to charge)My sister tried to turn it on, and all she had was the apple sign in black and white, and later, a check with the words "OK to disconnect" below it. All of this with the words "Disk Mode" as the tittle. I've tried pressing both the play and middle buttom for 10 seconds but it doesn't work. I've also tried connecting it to my pc, but i still get no results. Will SOMEONE PLEASE HELP ME!!!! Thanx |
dkirsty31 Unregistered guest | hey music less x I have exactly the same problem and dopn't no what to do as I don't want to buy a new i-pod mini as i love the one i have. So if there is ne1 out there 2 help please respond 2 us!!! Thank u x |
Unregistered guest | Hey people i have a 4th gen ipod rite 2ogb yeah sumtyms wen i play my songs it gets stuck and the frist tym it dun this it turned of and i recharged it was fine. but the otha day same problem and i thort ill wait rite so wen i got home i charged it but the onli prob was that (i connected it to my comp) the apple logo came up and afta 10 sec a ipod with a ![]() can u help me plz email me if u can too with the title ipod help!! stoog_y@hotmail.com thanks |
S2gey Unregistered guest | Hey guys guess wat its workin agen lol yesss WOOOOOHOOOOOOOOOOOO lol all altho u may not wanna do this. but just try to bang it on a table just under the usb thingo and reset it and it shud work well dats wat happen to me lol wel i am outtta here thnax anwayz i gonna listen to MUSIC ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Melody Unregistered guest | okay last night i went to plug my ipod in after it had been dead for awhile and it had the apple and the exclamation point and folder and it wouldn't work but i reset it and fixed it, but now when i plug it in, it says it's charging, but it doesn't show up on itunes and i cant update it, i tried reinstalling itunes but that didn't work, can anyone help me please? |
Johnnnnn Unregistered guest | hey people can sum one plz help me. ok i just restored my 20GB ipod rite dunno y? but now when i use my itunes rite (version 6) i cant update my playlists it says ipod update complete but all it does is create the playlist not actullay add songs on the pod plz help me thank-you John |
New member Username: Lil_miss_18LiverpoolEngland Post Number: 1 Registered: Dec-05 | Hey Dudes ... ![]() Am rele sad because me ipod Mini has froze on me ![]() Can any 1 help please? ... |
Anonymous | When i press the button to turn my ipod on a picture of an ipod with a sad face shows up. Please tell me whats wrong. |
IPOD SHUFFLE Unregistered guest | i really need some help with my ipod shuffle. it was working great until today i opened itunes and was shocked to see that there was only a little bit of space left on my ipod. i had about 20 songs on it and it was saying that i only had 119MB left...that was strange. i took off all the songs from the ipod and it now saying that i probably have about 250MB left. what's up with that? what is stored in the other 250? i'm at a loss here. i'm not storing any data on it and everything that was on it was put there by me only. can anybody tell me how to fix this? i have no idea what is mysteriously eating all the space and i really would like to fill my shuffle to its full capacity of music that i can listen to. thank you! |
Unregistered guest | I'm having the same sort of problems as above, with my iPod Mini. In iTunes it tells me that I have 138 songs, 9.7 hours and 615.4MB of music on my iPod. But then just above that it says that I have used 3.76GB and have just 2.8MB remaining. I don't see how this is possible because I do only have 138 songs, the average size being about 3 or 4MB. Please help! |
New member Username: MrkilljoyillPalmetto, Florida United states Post Number: 1 Registered: Dec-05 | my ipod mini aont play music anymore i meen it turns n and evrything and the song plays but it wont play on the headfones whats the deal???? |
New member Username: Spartana22Hillsboro, Oregon US Post Number: 1 Registered: Dec-05 | I Have a question.... ok i dont have anysongs on my ipod mini 4G (3.7) but yeah for some reason it says i have 2G used and and 1.6G left... can someone help me with this? thanks for your help |
Unregistered guest | okay so i restored my ipod mini & the software because it wouldnt turn on. now its on but everytime i connect it to my PC nothing happens. i open iTUNES and the icon isnt there. Ive tried re-installing iTUNES along with a new ipod update. Someone please help! thanks |
ipod mini Unregistered guest | hi people! how are you?anyway...a few days ago i tried to put some songs on my ipod from the pc but realized the battery was dead.the "!" came on.then the screen went blank when i pressed the middle button.i then unplugged it from the pc and recharged my ipod mini from the mains and left it.the next day my ipod wasnt charged...the screen was still blank...why why WHY?i think it's frozen but when i try to reset my ipod mini it doesnt work....i need help....quick!i cant return it because i bought it abroad.someonee,HELP! |
as23234jlasdaf84 Unregistered guest | i just got a nano and plugged it into my computer to get songs on it. nothing happens except in the bottom right corner of my comp screen a message appears saying "USB device not recognized." i dunno wat to do |
NYsalsaQn Unregistered guest | hey i got a question,everytime when i try and transfer songs from a cd , it tells me theres an error with the cd burning or something like that n that i have to re-install itunes software. so my question is, if i re-install itunes do ur songs get deleted? and if so is there anything i can do so none of my songs get deleted? does anyone kno? |
monicaaaaa8888 Unregistered guest | i just got a 5th generation 30 gb ipod and i am going on a trip and dont have a charger that uses an electrical outlet. Is there any way i cna bring my USB connector with me and charge the ipod on a computer that isnt mine. |
monicaaaaaa88888 Unregistered guest | if i delete all my songs off my itunes so my computer doesnt slow down, will all my songs be deleted of my ipod the next time i plug it in? |
Unregistered guest | Hey can someone please help me! ive had an ipod shuffle for christmas and ive done everything said and when i got onto the itunes it says that i have used 446mb and have 41.5mb remaining. This is very weired as i havent even put anything on it! please can someone help! anyone!?? |
Unregistered guest | Hi.. I am at a real loss here. I bought a new computer with windows XP. I loaded everything and then I installed iTunes, it worked great. Then my computer crashed so i had to restore. Now my iTunes keeps saying 'iTunes has encountered a problem and will close. Sorry for any inconveinence'. I have unistalled and reinstalled it loads of times to see if this helps, but it keeps saying the same thing. Can someone please help. (I do not have internet access at home and it says send this message, don't sed this message.) Thank you |
swoosh792 Unregistered guest | hey guys...i have a regular ipod with linux installed on it..it froze for some reason and none of the usual reboot techniques are working...what the hell should i do??? thanks for the help. |
King-Jonno Unregistered guest | heY, guess what. My ipod has frozen, I was updating k and it just stoped then it finally finished so i disconcted thenthe screen is just frozen at "do not disconecvt" can any one help?? |
Jayson____mack Unregistered guest | Hi there, I have an ipod mini, which i bought second hand. I can load 152 songs but no more, it is also still has games and contacts from the previous owner. The storage level is fine, with barely 1-8th in use. I can't reset it either. Does anyone have a solution? |
King-Jonno Unregistered guest | Hey my ipod ran out of batterys turned it on and it was fdine....FULLY charged t k then listedn to music as soon as i put it on i seen the bar drop...very slowey...but alot quiker than normal...so i left it and it drained within 45 mins a FULL charge what rong with it? |
laba713 Unregistered guest | My ipod mini froze about a month ago, so I reset it and left it here at school over Christmas break, charging the entire time. But when I hooked it up to put music back on it, etc. it started making this beeping noise and WON'T stop unless I keep resetting it....it seriously makes me want to jump out a window it's so annoying. The beeping happened several months ago, every once in awhile, but didn't make the ipod mini freeze like this. Anybody have any idea what's going on? |
caira Unregistered guest | you can do the nasty thing with me call 4353487 this is my photo |
New member Username: IpodminiPost Number: 2 Registered: Jan-06 | Ummm i have a question how do you get songs off your ipod that arent on your itunes anymore. |
Unregistered guest | Umm i just wanted to know how to get dates on the calender on my ipod mini.. |
Unregistered guest | Hi, this question has already been posted but I've not found the answer so sorry for repeating. I went to update my ipod and it said that it had updated..and that it was ok to disconnect it. When i disconnected the ipod it froze with the 'DO NOT DISCONNECT' screen... I've tried resetting it etc and it still won't reset...what can i do?? please help me... my emails 'simplyloveable@hotmail.co.uk' I really need help... I've tried everythingggg thanks caroline x |
Unregistered guest | hi, i was wandering, ihave an ipod mini, i have tried to turn it on, and no luck, so i have connected it to my pc, and a battery appears with an "!", then after a period of time, the apple logo flashes, then goes back to the battery screen, i have tried all the ways to reset the ipod, is there anything else i can try, please help me thankx you |
Anonymous | hello can anyone please tell me how do you erase music from your ipod!!!! im going insane crying my eyes out please help |
Unregistered guest | Ok someone must have come across this... i have a feeling my ipod mini is no longer for this earth. it won't turn on, won't charge, won't get recognised by itunes or the ipod updater, just shows folder and exclamation mark. is there anything i can do before i throw it into the bin? and yes, it's one month past it's year warranty! thanks apple |
Alan G Unregistered guest | Hi, My mini ipod was sent for repair and replaced with new one. All my music was on the ipod, not in my libary. I have recovered the music folder (3.8g) from my old ipod and I need to know how to get this data onto my new ipod or into itunes. Greatful to any one who can help... |
Mandy K Unregistered guest | hi, i have a 4 gig ipod mini. i've had it for about ten months, but this just started happening recently. my battery bar says it has a full charge, and so does the computer when the pod is connected to the usb cable. but when i turn it on and scroll and pick a song, when it starts to play, a message says "no battery power remains, please connect ipod to power source." and then it turns off and shows the low battery symbol. if you try and turn it on that apple symbol comes on, and so does the low battery symbol, and then it just shuts off. if i wait 5 mins and try again, it will turn on but the battery bar will be empty and will then shut off again. help me please!!! |
bluraven Unregistered guest | I had a problem with the music quiz giving an error that there were no songs found, like a few other posts that I read. I fixed it by resetting my nano holding the select and menu buttons down for a few seconds, after it rebooted the music quiz found all the songs and started working agian. Just thought I'd share incase anyone else had that problem too. |
ScottishJenny Unregistered guest | Hi, im simpithying with all these other mini ipod people! Mine hasnt had new songs on it for about 6 months because even though i have downloaded songs onto my computer, "update ipod" is never highlighted, and therefore i cant click on it, and therefore cant get new songs onto it. Is my only option to take it back to the factory settings and start all over again? if anyone has any suggestions, that would be fab, but if your answering, bare in mind im a bit of a dunce when it comes to computer stuff!! ta, J |
spanishlady123 Unregistered guest | my mini ipod frooze a while ago o i decided to connect it back to the computer see if it did anythin. now a syumbol has appeared looks like a folder with this next to it ! any idea how i make it work again? |
Anonymous | HELP!!!!!!!!! My Ipod When I Turn It On comes up with the apple sign then a battury with a ! what can i do it worked fine for a month when i brought off my friend but battury went quick but now won do anything if i connect it :'( Plz help i no i may need a new battury how much are they and where do i get them from plz help me lol thanks :D Lozzy -x- |
Lozzy Unregistered guest | I Have The Same Problem As Ipod Mini!!!!!! I Cant Return PLZ PLZ PLZ Help I have A Blue Ipod Mini But Not In Use Please Help Me!!!! |
Lozzy Unregistered guest | SpanishLady go on this website when i was looking for my problem i think i found urs :D http://www.apple.com/support/ipod/ theres a pic of ur problem saying "what is this icon" I hope that helps ![]() |
skokenator Unregistered guest | PLEASE HELP ME!!! i have a bout 407 songs in my ipod library and over 2000 on my ipod..so i plugged in my ipod to my computer (its set on manual update) AND ALL MY SONGS HAVE BEEN ERASED!!! i dont know what to do...the weird thing is that all my pictures are still there HELP PLEASE |
looooooooooooooo Unregistered guest | ok i have an ipod mini and i recently got the new video ipod.How would i be able to put the songs from my ipod mini onto my new ipod? because when ever i try to move the songs from the ipod mine to the library it wont work. HELP!!!!!! |
New member Username: Shinymelly18Post Number: 1 Registered: Jan-06 | hi my ipod mini's screen is frozen on a song, i tried taking it off and plugging it into the computer nothing is working. plz help |
JP_in_Sydney Unregistered guest | hi after restoring my ipod - I got the file with !. It then told me to plug into mains - problem was that my adapter wouldn't work. Anyway I went to a store and stuck it in their mains. It showed that the ipod had been wiped but showed the menus etc. However when I connected to my laptop it all started over again and wouldn't mount etc. It then got stuck on Do Not Disconnect so I couldn't turn it off. Now it has been drained and will not recharge. Is there anthing I can do? it still has enough power to show the apple logo when I touch the click wheel, but that's it. |
DykhoffD Unregistered guest | I can't download the most recent ipod updater. When I click the download button on the ipod site I get the red fist, then the page changes and tells me that download will start automatically, but nothing happens. |
New member Username: CatneyPost Number: 1 Registered: Jan-06 | my lil bro has buggered up my ipod wen i turn it on it ses firmware problem then goes straight to a recovery mode. think u need a software cd? but i brought this off a mate so i aint got one. cant get one off him either cos i aint seen him since. any suggestions? |
Unregistered guest | my ipod mini only shows the apple sign. it makes clicking noises like the inside mechanism is doing something and at regular intervals the sign disappears for like 1 sec then it all starts again. i've done everything on the apple website. it wont turn off until it runs out of battery and then if i plug it in again it just starts doing it again. i've seen this problem on several comments above but no one's answered it I NEED SOMEONE'S HELP MAN! I LOVE MY IPOD MINI! |
iheartapples Unregistered guest | hey, the same thing happened to me and im not sure what it is and i took it to the nearest apple store and they fixed it immediately, the guy couldnt explain what happened but the stores dont charge for it so no problem luck |
Unregistered guest | hey..i recently just got my iPod fixed, and it works fine BUT...i somehow dont have my iPod registered to my iTunes..does ne one have ne idea in how to do that?? |
ShfM Unregistered guest | Hello. I've recently reinstalled windows onto my hard drive so the entire hard disk was formatted. Since, my iPod Mini has the folder with a ! displayed. I no longer have the original installation disk (bad I know) and I've tried all the recommended solutions to no avail. I have the latest iPod updater (01-10-06) and iTunes version 6. Yet my PC won't register the iPod Mini. Can anyone help? |
Miranda Unregistered guest | Okay, so I bought a 4GB iPod Mini around 3 months ago. I charged it one day, then didn't use it the next day - when I go to turn it on I get the apple sign, and then the picture of the iPod with crosses as eyes and a sad smile. What has happened? Do I have to take it to get it repaired? And why has this happened? |
Unregistered guest | When I turn on my iPod mini it shows a picture of the adapter pluging into the wall. So when i pluged it in for acouple hours it said the same thing when it was charging and after leving it in there. What should I do? |
Nowell Unregistered guest | I got a ipod nano and well i let the battery go out completly , then i plugged it into my computer to let it charge, but then a different symbol came up and my computer didn't pick up that my ipod was connected. So it didn't charge alwell , and it also it made a bleeping noise.......SOMEONE PLEASE HELP ME! |
alice Unregistered guest | hi i dropped my ipod and it froze.so my brother restored it.but now it has a folder sign and caution sign underneath the foder.it wont do anything else. WHAT DO I DO NOW? PLEASE HELP. |
Unregistered guest | One half of my daughters iPod nano screen is not active. Rebooting the iPod does not help. Any sugestions besides sending it back to apple for replacement? ANyone else have this problem? |
Nowell Unregistered guest | I got a ipod nano and well i let the battery go out completly , then i plugged it into my computer to let it charge, but then a different symbol came up and my computer didn't pick up that my ipod was connected. So it didn't charge aswell , and it also it made a bleeping noise.......SOMEONE PLEASE HELP ME! |
Unregistered guest | I bought an Ipod mini froma friend and he didn't have the sofware disk but he gave me everything else. I updated the ipod and it worked and then a picture of a socket plug in came up and I pluged it into the adapter and plugged it into the wall and the picture is still there and it's not frozen because it will turn off and stay off but when I turn it on that same picture keeps popping up and it won't reset, and now it won't even show up on my cpu, i tunes, or updater. It just shows that little wall outlet. What's up with this? |
Anonymous | I was just about to bring my ipod with me until the apple symbol showed up and is doing all these tests and won't let me turn it off or play any music. and on the tests when it tells me to press these buttons it won't do anything sord of like when a computer is frozen . so i some DESPERATE HELP!!! i don't know what to do. and i want to listen to it. HELP!!!!!! |
Unregistered guest | I have an iPod Nano that is formatted to work with my Mac, running OSX. I was traveling and wanted to recharge the Nano but used my PC to do this. It appears that the Nano charged ok but all of my files have been erased or at least appear to have been erased. Is it possible that when I plugged the Nano into the PC that the Nano got confused by a different OS and erased everything? If so, will I need to 'restore' the Nano then reload what I had on there originally? Thanks! |
Unregistered guest | Hiya. i brought a mini ipod second hand, and it was working perfectly. one day i let the battery run dead ( i now kno i shudnt hav) and wouldnt charge. a day later i plugged it into my laptop and it charged fine!! recently, i went to charge up the ipod again, but this time, the apple icon appeared an then just went off. nothing happens now. the computer doesnt recognise it and the ipod isnt charging. please help as i need my music to survive!! lol!! Thanks a lot |
tk0055 Unregistered guest | I know how to put songs from ITUNES onto my Ipod Mini, but how do I download music from my Ipod Mini into my ITUNES library? |
never Unregistered guest | hey...ive got a slight problem and cant figure it out...when i log on to iTunes it wont let me connect to the music store it keeps saying check connecting...well i have and nothings rong with it i dont have and firewalls or anything like that...if any of you have an idea...email me at nevin_h_8519...or IM me on yahoo at after_9_coronas or AIM at budwiser8519 |
never Unregistered guest | hey...ive got a slight problem and cant figure it out...when i log on to iTunes it wont let me connect to the music store it keeps saying check connecting...well i have and nothings rong with it i dont have and firewalls or anything like that...if any of you have an idea...email me at nevin_h_8519@yahoo.com...or IM me on yahoo at after_9_coronas or AIM at budwiser8519 |
Anonymous | big problem over here....i was about to update my ipod video and it gave me a message saying there was a new update for it so i clicked yes and did the update...after that my ipod had the apple logo and didnt do anything when i pressed all of the buttons so I waited awhile to see if anything would happen and nothing did....so I stupidly unplugged the USB from the ipod and i tried resetting my ipod...after it reset, it would make this beeping noise and would stay at a blank white screen..SOMEONE HELP PLEASE!!! |
Lab Unregistered guest | i sat my ipod mini down yesterday next to my cell phone it also is usually in my purse with each other. now my ipod is totally dead it had a full batterie and everything. i tried plugging it in the charger and pc. but the screen is just blank. would the cell phone have to do with anything. please help me!!!!!!! |
Karine Unregistered guest | Ok the other day i was listing to my pink ipod mini as usaul when all of a suddened it started playing throw all my songs really fast i thought it was just scanning all of them. So i shut it off and when i tried to turn it back on a ipod icon with a sad face on the screen and an explmation point (!) showed up i was kinda worried. Now i already tried restarting it with you hold on bottons and all that other stuff. So i was wondering if you could help me with this porblem PLEASE!!!!!!!!!!!!!!thank you |
Matt69 Unregistered guest | I have the same problem as ScottishJenny trying to update new songs onto my ipod mini. Any help would be great. |
Unregistered guest | hey i just got a 30gig video ipod and i was wondering if anyone knows how you put pictures to your albums, like the covers of them i would be v.grateful if anyone could help me ?!?!?!?!?! |
Unregistered guest | I have the sad ipod face syndrome...i bought my 4G ipod mini 4 months ago, everythings fine, until one day it froze. I did the hold button,push menu and play reset thingy over and over again until i think i squashed the poor wheel...the apple sign does come up only to be followed by a sad face ipod...then nothing... i tried pluggin into my computer at home and at work and it doesnt show up on neither...not on itunes and not on windows hardware devices....i know i have no problem with my USB ports, and i used my ipod on my home computer that didnt have SP2 on it and it worked before , as well as using it on my work computer (that has SP2) and it worked fine there before as well.... i installed the newer software offa apple's website...still to no avail.... i unfortunately live abroad where no Apple stores exist , so i think ive just wasted 300 bux for nothing ![]() please if anyone can help, it will be greatly appreciated (ps only one thing i havent tried, reformatting my windows, what a drag!) |
Gold Member Username: Project6Post Number: 6674 Registered: Dec-03 | If the sad face pops up on your iPod...the iPod is dead. You cannot fix it with any button combination. You have to send it in or try to fix the hard drive on your own...which you probably don't want to do. |
New member Username: HemulpolisenPost Number: 1 Registered: Mar-06 | What is the problem if the iPod shows the power outlet icon, but plugging the iPod to a power outlet doesn't help? This happens to me after I updated my iPod mini to 1.4.1. The battery life was fine before this. |
New member Username: Sara101Post Number: 1 Registered: Mar-06 | Hi, i have 1st generation ipod, which is old i know. but it is pretty much new.. It gets frozen on the apple symbol sings, which is right before you restart it.. . I have tried to restart it lots of times but it just goes back to the same screen (frozen apple sign).. i also flip the hold switch on and off and try and restart it again but it still doesnt work.. I restart it by holding the menu and the play/ pause button,, i have also tried hold all the buttons at once.. please help |
New member Username: Xxelement05xxPost Number: 1 Registered: Mar-06 | i have an ipod mini. im guessing its a first generation im not exactly sure. i got in for christmas in '05 i believe. i had lost my ipod for a few months then found it in my car and it still worked fine. i was letting my friend borrow it for the weekend so i plugged it into her usb port to charge (i put my itunes on her comp.) and it displayed a battery with the lightning bolt but it wasnt charging it was just sitting there. i know i still had a little bit of power left on it. after that weekend i plugged it into my computer and it says the same thing and itunes doesnt recognize it anymore, it didnt show up. they tell me to reset my ipod but when i do it shows the apple for a second and shows that sad ipod face with a ! mark. i cant put it into disk mode, it wont charge, and i cant update it or restore it. is there anything i can do? ill try using someones wall charger to charge it but i still dont know what to do after that. plz help! |
New member Username: Lily2931Post Number: 1 Registered: Mar-06 | hello. I recently recieved a new computer--I don't have any songs stored on iTunes, their all on my iPod. If I were to plug my iPod into my new computer would all the songs on my iPod be erased if there isn't anything in the library...or is there a way to retrieve the songs I had on my account (stored in the iTunes library on my old computer) before I got a new computer?? Thanks very much |
New member Username: Zooyork350Post Number: 1 Registered: Apr-06 | i have a wierd problem with my ipod mini, i can transfer songs from itunes to the ipod with no problem and they show up on the ipod, but they just won't play. i can even load the songs off the ipod and play them, but the ipod itself won't play any music; the time just stays at 0:00 and then it usually freezes |
New member Username: Sara101Post Number: 7 Registered: Mar-06 | Hi, I have the 1st genertation ipod with the scroll wheel. My problem is that the Apple Symbol if frozen on my screen. It is from when you restart it and the APPLE SYMBOL pops up and then it goes to the usual menu. But its completly stuck on that symbol. I have restarted and restarted it many many times, and the screen will go blank and then it will go back to the APPLE. I have fliped on and off the hold button but still wont work. I have plugged it into my comp. but the iTunes doesnt seem to reconize the ipod..!!!! PLEASE PLEASE HELP!!! |
New member Username: JonnPost Number: 1 Registered: Apr-06 | Help Me please I just got an ipod mini from my friend and every time i turn it on a unhappy sign comes up i tried all of the stuff from the apple website but none of it work i currently have itunes 6.0 or higher Thank you for your help |
New member Username: DcrazyperuanaOssiningUS Post Number: 1 Registered: May-06 | COULD U PLZZ HELP ME WITH MY IPOD MINI!!!! UMM...MY FRIEND DROPPED IT AND DA SCREEN FROZE SO I WAITED TILL DA BATTERIES DIED AND THEN I CHARGED IT AGAIN AND WHEN I TURNED IT ON IT GOT STUCK ON DA APPLE LOGO!! DIZ IS DA FIRST TIME IT FREEZES..I DUNNO WHAT TO DO!!! IVE TRIED PRESSING DA PAUSE AND MENU NUTTONS ALSO DA MENU AND CENTER AND A BUNCH OF DIFF. THINGS BUT ITS NOT RESPONDING....IF U COULD HELP ME ID REALLY APPRECIATE IT!!! THANX IN ADVANCE...=) |
New member Username: Katie_helpLondon, Guildford England Post Number: 1 Registered: May-06 | I Also Have The sad face syndrome for my ipod mini !!!!!!! HELP, ok so my friend gave it to me to have if i could fix it! i have tried resetting it but it just SHOWS THE APPLE ICON THEN THE SAD FACED IPOD(!) help what do i do? my dad though about buying a new battery ??? but i think he should take the ipodmini apart and try and fix the hardrive, but i don't know what to fix PLEASE HELP me thank you it would be MUCH appreciated!>> |
New member Username: SmithersPost Number: 1 Registered: Jun-06 | I use Windows 98SE, and was able to use XPlay to transfer my music. When the trial ran out, I tried Anapod, and it wiped out my music. I thought no problem, I'll just back it up on my PC. Then I accidentally "formatted" it or something, and now not even the "Music," "Extras," or those files will show up, and only a file with an exclamation point does. I don't have the Updater, because I use 98SE, so how can I restore my ipod without it?? |
New member Username: Ka_y_laChina, Lolol China Post Number: 1 Registered: Jun-06 | HELP ME...ok this guy names jake always takes my ipod. and then i was serching my ipod and i found out u can put a code on it. well i did and now i forgot my code...AHHHHH i need my ipode mini i love ti im gunna cry HELP ME PLEASE |
New member Username: SmithersPost Number: 2 Registered: Jun-06 | Is Jake hot? And what does he have to do with it? Try and think of what your code was... Was it a name of a pet? A name of a friend? Think of these things. |
New member Username: Lakeviewchick15Rossville, Ga United states Post Number: 1 Registered: Jun-06 | my ipod comes on and then it freezes at the apple loadin screen and when i hook it up to the computer it says do not disconnect and then some wierd folder pop ups on it so what do i do???? |
New member Username: LucyjPost Number: 1 Registered: Jun-06 | first reset the ipod by holding down the middle key and the menu key, plug it into the computer(even though it may not do anything) for 3hrs. if it doesn't work, go into the Apple store GOOD LUCK! Lucy |
New member Username: LucyjPost Number: 2 Registered: Jun-06 | DO IT! |
New member Username: Schoolgrl856Post Number: 1 Registered: Jun-06 | hey ... um my ipod mini was fine until my friend threw it to me and i missed .. it hit the board and then the floor and now it says www.apple.com/support/ipod with a folder and a exclamation point.... ive gone to the site and done everything it said i even tried putting it in disk mode ive done everything ive gone to muliple sites and done almost everything i could to try and fix it and even when i put in my comp it wont read in My computer or on iTUNES .... im at a friends house and i tried it on her computer to see if i was just my computer that wouldnt work ... but it wont work bc her ipod worked and mine didnt im just about ready to pawn it and save up to buy another one because nothing is working can u please help me ? anything would be great right about now thanks =) -kouazou email: Schoolgrl856@yahoo.com .. if u can (: thx |
Gold Member Username: Project6Post Number: 8290 Registered: Dec-03 | Of course it will not be fine. IT HIT THE BOARD AND THE FLOOR!!! What did you think will happen??? That device is not a frisbee and not shock proof! You drop it and it will get messed up. Drop anything electronic that is not designed for dropping will get seriously messed up. Send it in for repair and take better care of it. Have your friend pay for the damages. |
New member Username: LilstarbucksgalWilmette, Illinois United states Post Number: 1 Registered: Jun-06 | umm. ive got two problems. =) 1.) my mom erased my normal computers memory cuz our popup blocker wasnt working and all of these popups were coming out.. so it was deleted, and so was my entire itunes library which had a lot of songs and a lot of bought songs. i still have all my songs on my ipod, but how do i get them onto my library again? 2.) so our computer was fixed, but then it became broken again.. so my moms erasing its memory again. but i put some videos onto my library so is there anyway to store them onto like.. a cd? please replyy |
New member Username: KittykassPost Number: 1 Registered: Jun-06 | hello, I have two problems hopefully you can help me with. I've been charging my ipod for a couple of hours now and the "do not disconnet" will not stop flashing? When I connect my ipod to my usb port, my computer reads songs,as diana's I-POD( H: )drive and I can listen to them using MEDIA PLAYER. when I disconnect my IPOD from the computer and try to listen to the songs on my IPOD, my IPOD is showwing NO SONGS on it?? I know the music is on there but I don't know why I can listen to it? Can you please help. Thank you, Diana |
New member Username: IntoxthefirePost Number: 1 Registered: Jun-06 | My 4GB iPod Mini is only about a week old. I was in my pool and my suit was wet. The Mini was laying on my suit [i was on a floatie] and when i picked up my mini, the back was wet. Being very protective of it, I immediately got out of the pool. I tried to switch the song but none of the buttons responded. I got them to work a little while ago by restarting my Mini but when it turned off and back on again, it went back to not working. I keep restarting it and plugging in the USB but nothing has happened since the one time. I need some serious help here. Should I call the people at Apple? Send it back and get a replacement? please help |
New member Username: Bailey84537574534453Post Number: 1 Registered: Jun-06 | Help.. my ipod won't turn on at all and when i plug it into the computer it starts making funny noises and i don't know what to do |
New member Username: Wl125Post Number: 1 Registered: Jun-06 | i have an ipod mini and i want to upload music onto it but i have windows 98 and can't use itunes...is there any other way to put music on an ipod besides itunes?? please help |
New member Username: Maddie_xxoPost Number: 1 Registered: Jul-06 | hey ive had my ipod mini for quite a while now. it died about 2-3 months ago and i havent used it since, it just wouldnt turn on. But recently ive plugged it into my computer and it shower a battery with a triangle with a ! in it. so it said do you want to update so i did. and then the wall charger popped up so i put it in there and it updated but now it says "No batter power remains. Please plug ipod into power." but when i plug it into my computer is says that it is charging but when i take it out there is no bar. what do i do? any information you have is greatly apprectiated. thanks! |
New member Username: Gangsta041Post Number: 1 Registered: Jul-06 | wen i go to update mi ipod it leaves the old music there and the new music doesnt go on. wen i go to hit the update button it wont let me. |
New member Username: SmithersPost Number: 3 Registered: Jun-06 | to whitney: there are many sites and programs you can use to do this. my preference is xplay. just go to mediafour.com, and click on programs, then go to xplay. download the free trial. |
New member Username: Katerose16Post Number: 1 Registered: Jul-06 | my 4 gb ipod mini has a problem that i dont know how to fix. I turn it on, it shows the apple sign, and then it shows a sad ipod icon and shuts off. I have tried reseting it and all of that and i cant even restore it to factory settings bc when i open ipod updater it says ipod manager internal error and the window closes. How can i fix this without having to go to the apple store and paying for it to be fixed by them?? |
Gold Member Username: Project6Post Number: 8795 Registered: Dec-03 | The sad face on the icon means that your iPod has a bad hard drive and needs to be serviced professionally. You can try to fix it yourself by replacing the hardrive. Have you done any electronic work? |
New member Username: BansheeboyPost Number: 1 Registered: Jul-06 | my ipod makes a clicking noise rifht when I turn it on and then it goes to the flippin unhappy sighn how the hell do I fix this please |
