Ok so I'm wondering a way to get 2, 4 ohm voice coils to run at 2 ohms to the amp? Well ok I kinda just wanted to see if this would work, or what? OK so I took one sub and wired it series and then I took another sub and wired it parallel. Then if I take the ends of each set of wires and bridge them at the amp will that give me 2 ohms total like I think it will, or will this just mess up the whole plan? Using the multi-meter I have a 2 ohm load but I'm just not sure if this would work? Somebody help!!!!!
