hi all,my problem is i traded my gf's sister cd players and she ended up selling the car b4 i was able to get the male stereo plug out of it.now i have a stero w/out the plug.pioneer wants 40 buks fer a replacement which i cant afford.is there any sites or anybody who knows which pins do what so i can rig sumthin to werk?any help would be greatly appreciated,thanx
I seen the wiring harness for the pioneer deh 345 on ebay go to ebay and look for pioneer deh 345 and you will find some not that bad of a price. hope this helps
thanx,but im not werking.i was just planning onghetto-riggin it(pins n wires).i found 1 online for $50,i can get anuther cd player fer that much.
s hebert
pin #1 left front positive pin #2 right front positive pin #3 12 volt batt/constant pin #4 12 volt ignition/switched pin #5 right rear positive pin #6 left rear positive pin #7 left front negative pin #8 right front negative pin #9 ground pin #10 system remote pin #11 right rear negative pin #12 left rear negative
pin # 1 being on the lower right corner of plug pin #2 to the left of one and so on til pin # 6 pin #7 is on the top right hand corner giong again to the left with pin # 12 being on the top left hand corner
