New member Username: LaininjapanAtlanta, GA USA Post Number: 1 Registered: Jun-05 | I have searched a few needle replacement sites and am havig some trouble figuring out WHICH needle is the correct replacement. The needle that the player came with broke before I got it (I guess during shipping). Anyone know where I can find this out? |
Silver Member Username: Stu_pittNYC, NY Pakistan Post Number: 112 Registered: May-05 | I hope this link helps - http://www.turntableneedles.com/index.asp?PageAction=VIEWCATS&Category=21940 I don't know anything about your turntable, but this may help you determine what type you need. |
Bronze Member Username: DvautierBellevue, Wa Usa Post Number: 17 Registered: Feb-05 | I had a dual 1009 and a 1019 and as I recall they both take standard carts. I would suggest you invest in a good cart like a sure m97e and use it. As long as you have a decent headpiece, I think it will work fine. |
New member Username: LaininjapanAtlanta, GA USA Post Number: 2 Registered: Jun-05 | Thank you (both Stu and Dominic) for the advice. I'll try that link out and look at the m97e. |
