Elite VSX-43TX vs. VSX-55TXi: Specific construction differences?
AudioVideoGuy
I am curious as to what the performance differences are between the two (VSX-43TX vs. VSX-55TXi) in terms of construction etc.?
The site lists some specifics, but a direct comparison, in terms of ALL the construction specifics, isn't provided.
For one, it seems the 55TXi has a 'double layer' chassis, which the 43TX may not have.
If anyone can provide some details of the performance and construction differences (other than functional features) between the two, I would appreciate it.
Thanks!
Username: Paul_ohstbucks
Post Number: 1401
The construction build quality will be the same for each model.
The differences are in the features. Make your decision based on those differences.
