Max Input Power
i checked out the paradigm studio 40 online and the specs mention a maximum input power. in the studio 40 the max input power is 140 watts and the range is 15-180 watts. im just not sure what the 140 watts max input means if some can help me here. also do these requirment also apply to all speaker
Username: Timn8ter
Seattle, WA USA
Post Number: 11
It's pretty much a worthless specification that gets attention only because so many consumers are convinced the wattage rating equals quality. If you have a typical solid state amp/receiver you'll be fine. If your amp only puts out 5 watts per channel then those speakers will not work well for you.
Username: Elitefan1
Post Number: 285
Speaker power ratings are not as important as what is driving that particular speaker. A low powered receiver cranked up is much more likely to blow a speaker than a more powerful unit that puts out lots of clean power. A speaker rated at 100 max will blow if a 65 watt receiver being overdriven is clipping but a receiver putting out 150 watts of clean power will not blow that same speaker. Just buy a receiver like a NAD or Rotel and you'll have no problem.
