New member Username: ZaigherPost Number: 1 Registered: Jun-05 | I am listening mostly to clasasical music(a lot of piano solo). My Marantz SR4200 does not sound very well with my B&W 603 S3 speakers. I am looking for a stereo integrated amplifier to match my speakers and my music. Gery |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 4227 Registered: May-04 | https://www.ecoustics.com/electronics/forum/home-audio/140638.html |
Silver Member Username: EdisonGlendale, CA US Post Number: 732 Registered: Dec-03 | You might try using your computer as the source - with a soundcard upgrade to waveterminal u24 ($160 on www.ebay.com). You can treat the jitter problem this way - and is convenient to have your collection under your finger tips. Later, you can even add a good DAC to further improve the sound. If you are still not happy with the sound, you might want to upgrade the speaker - B&W is a respected British company, but only their upper models sound really good. But your idea about a different amp is a good one - will improve the sound some what. Buy them used at www.audiogon.com or www.audioweb.com and save - this way, if you are not happy with it, you can re-sell and not lose much. It's fun to experiment with different audio gears - and buying used, your loved ones wouln't give you that look either. |
bumblebee Unregistered guest | How about Rotel's RA-1062? |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 1060 Registered: Feb-05 | Either a Rotel or an NAD integrated would represent a considerable upgrade. |
