Denon AVR 2105
Username: Wilcster
BridgetownBarbados
Am just piecing together a new system. Principally to listen to music, but eventually to integrate with TV. I intend to buy the following:
NAD C521BEE CD player
DENON AVR-2105 Receiver
MISSION M33i Loudspeakers
Does anyone have any comments on compatibility etc. And should I/ can I biwire the Mission speakers using this equipment??
Username: Rikmeister
Hometown, Pa Usa
i would look at the denon 3805 more options with that one. look on ubid or ebay for one. for a cd player i would look at the oppo it is rated very good for 199.00 speakers i am partisl to paradigm do not know much about mission maybe someone else does.
Username: Wilcster
BridgetownBarbados
Cheerz Rik. I may have to change my approach on the speakers due to local availability. Will take a closer look at the Denon. May also look at the NAD T753.
Username: Edster922
Post Number: 979
If music is your priority then definitely look at NAD...if you auditioned the NAD and Denon side by side in a store I'd be very surprised if you went for Denon.
