Maranzt 5400 Nad C320BEE Wharfedale Diamond 9.1 RCA QED Silver Spiral Cables QED silver anniversarry bi-wire
I like almost everything about the system and now am planning to upgrade a subwoofer and I've read fantastic review of the wharfedale SW150, I listen mostly to slow jazz and medium low volumn but I seem to find the lower end missing even at this low volumn. The question
How do I connect the sub to my amp? can I use the pre-out from the amp hook it to the line level input and loop back from the line level output from the sub to the amp? Will doing this when I cut the frequency level say at 50Hz nothing beyond this goes to the diamond 9.1 and ONLY handle by the sub? Will it in anyway affect the clarity I'm currently enjoying when I put out a long RCA looping. (I'll be using 2 pairs 2meter QED Qunex2)
Thank you and hope you can advise me soonest as I should be shopping for a subwoofer this weekend.
bkfinest
i have 15 inch sub at 500 watts and 100 rms.what wattage and rms and ohms amp should i use.i'm just looking for numbers on what to buy .or should i return the sub and buy something else?
