Danielson Unregistered guest | it ALWAYS SAYS IT FAILS to check out.. i use netMD! someone help? |
New member Username: KallitypeVashon, WA Post Number: 3 Registered: Jun-05 | No can do. Many threads about this, no way to transfer mic recording from Md to PC. Try gettting a double male stereo cable and go from the headfone jack on your MD recorder to the line input of your pC. |
Unregistered guest | You'll need a program called WinMD to transfer files from md to pc. I have been looking for it guite a while now on the web etc. Can't find it anywhere... If anyone has it(WinMD), please send it to me at erto@Snowboard.com |
