B&O TX2 stylus
isjcinu
Does anyone know if the original stylus on this B&O table is proprietary and is irreplacable? I'm trying to decide between a new table and replacing the stylus. Any suggestions?
Username: Jan_b_vigne
Dallas, TX
Post Number: 4205
B&O tables could only use B&O cartridges. Anything that fit the TX2 is long out of production.
You can find replacements on eBay, www.steroneedles.com or soundsmith. Not really a problem.
Small correction ...www.stereoneedles.com also try ElexAtelier (your browser will find all these easily if you type in MMC2).
Username: Joe_c
Oakwood, Ga
Post Number: 502
Elex is very fair his website is www.lpgear.com
