lost101 Unregistered guest |
Posted on can 4 ome speakers be used on 8 ome audio systems in any way. |
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 4125 Registered: May-04
Posted on You can put 4 OHM speakers on top of an 8 OHM system to hold it down. Or underneath it to prop it up. Those are the best uses for what you have asked. |
Posted on Cold, really cold. His moniker is lost, as in, I need help. |
Dallas,
TX
Post Number: 4129 Registered: May-04
Posted on Was I not honest in my assessment? Feel free to give a more appropriate reply.
